Results 1 to 31 of 31
    Senior Member Four Rings 317ssayzarc's Avatar
    Oct 27 2007
    98.5 A4 2.0T 2001 Golf 1.8T
    Westerly RI
    Post Official Displacement Increasing Thread
    This is the official thread for increasing the displacements in both the 058 and 06A blocks.
    To answer the question, “should I go stroker or not?” it’s different for everybody. In my motor, I was going to drop in rods and call it a day. After disassembling my motor, I checked wall to piston clearance and I measured .004” which is too much. So I had to overbore. Since I was buying pistons and rods, I decided to just buy a crank at the same time. If you buy overbore pistons and later decide to stroke your motor, you will have to buy pistons again, which I was wanting to do so I did it all in one shot. Another thing that made me think about doing pistons from the beginning was that I wanted to lower the compression ratio so I could run higher boost on pump gas. Basically, if you are replacing your pistons and rods, you should go stroker.
    First, you need to know which block you have in order to determine what course of action you need to take.
    Here is how you can tell if you have an 058: you have an engine coded AEB or ATW, you have an external water pump, you have an intermediate shaft (IM shaft) for the oil pump, you have no knock sensors, you are drive by cable, ect…
    Here is how you can tell if you have an 06A: you have an engine coded AWM, you have an internal water pump, you have no IM shaft, you have knock sensors, you are drive by wire, ect…
    Displacements are as follows:
    81mm bore x 86.4mm stroke = 1781cc (stock)
    81.5mm bore x 86.4mm stroke = 1803cc
    82mm bore x 86.4mm stroke = 1825cc
    82.5mm bore x 86.4mm stroke = 1848cc
    83mm bore x 86.4mm stroke = 1870cc
    83.5mm bore x 86.4mm stroke = 1893cc
    Now when you add a 92.8mm stroke crank to you engine you have the following displacements:
    81mm bore x 92.8 mm stroke = 1913cc
    81.5mm bore x 92.8mm stroke = 1937cc
    82mm bore x 92.8mm stroke = 1961cc
    82.5mm bore x 92.8mm stroke = 1985cc
    83mm bore x 92.8mm stroke = 2009cc
    83.5mm bore x 92.8mm stroke = 2033cc
    I will not go into the 95.5mm crank from the TDI as I do not know enough to accurately inform people about making it work in either the 06A or 059 blocks.
    Since this is for the B5 forum, I will start with the 058 block, since most of us have that. Stock bore is 81mm, pistons are generally offered in .5mm increments over stock, there are some exceptions. JE, Mahle, Wiseco, CP, and Supertech are the popular choices, not to say the only ones that are good. For rods, you use stock length and 20mm wrist pin. Scat, Pauter and Carillo are the popular choices, again, not the only ones that are good.
    For using a stock crank, the process is pretty straight forward. You tear down the motor and bore the cylinders. Install is the reversal but with the exceptions of putting the new slugs in.
    For stroking the motor, the process is much more involved. You need pistons with a lower deck height due to the increase of stroke. The same rod dimensions are used and if the stock height pistons were used, the pistons would travel 3.2mm too high and impact the valves. Not good as you can imagine. So custom pistons will be needed and they are readily available for order because luckily for us, others have been doing this and the design is already done. Which crank do you use? Well since you are 058 you must use an ABA crank from a MK3 Volkswagen. Pre OBD2 cranks are forged, post are cast. Chances are you won’t be coming anywhere NEAR breaking either unless you are going about a 35R or beyond. Now for the installation of the whole setup… A couple things will need to be done to make clearance for the rods due to the larger stroke of the crank. #1 The block will need to be grinded away by about 1.5-2mm on the side of the block away from the IM shaft. Cylinder 3 has a hump that the rest do not and that will need to be ground a bit more. The rods will actually clear without any grinding, but you should have at least .100” clearance in my opinion. #2 The cylinder 4 oil squirter will need to be moved away from the piston using a copper o-ring between the block and the squirter. You will also need to grind the corner closest to the back of the motor and closest to the cylinder. #3 The IM shaft will need to be modified. The gear will need to be machined down to a thinner size. The amount needed to be removed depends on the type of rods you use, mind you only a little bit, but it does matter.
    For the 058 you will NEED the following to reassemble your motor:
    Crank bearings
    Main Bearings
    Main Bolts
    Head bolts
    Flywheel bolts
    Rear main seal
    IM shaft seal
    Headgasket (if you are going past 82mm bore a head gasket from a ALT will be needed)
    Oil pan gasket
    Front seal
    Valve cover gasket set
    You SHOULD do the following things as well:
    Oil pump
    Timing Belt
    Rollers and tensioners
    Serpentine belt
    Water Pump
    Thermostat
    Now on to the 06A block things are a bit easier for a stroker. The same applies for the stock stroke builds, just bore and put in new pistons. The reason the stroker crank is easier to run is because nothing has to be clearenced. Just install your new rods, pistons and crank and you are good to go. You have several options for crankshafts. For drop in solutions you have the AZG and AEG cranks. The AEG and AZG are from MK4 2.0’s and are cast in construction. The other options are ALT and BPV which are from a B6 2.0 FSI found in Europe. They have the wrong oil pump gear and need to be modified to be used in this application. The ALT is cast and the BPV forged. If you have the correct oil pump gear pressed on, the ALT and BPV can be used just like the AZG and AEG, just drop in and go.
    For the 06A you will NEED the following to reassemble your motor:
    Crank bearings
    Main Bearings
    Main Bolts
    Head bolts
    Flywheel bolts
    Rear main seal
    Headgasket (if you are going past 82mm bore a head gasket from an ALT will be needed)
    Oil pan silicone sealant
    Front seal
    Oil pump
    Timing Belt
    Serpentine belt
    Water Pump
    Thermostat
    Now for the credits:
    Issam Abed (wizard-of-od) for providing me with every possible crank option there is lol
    Paul Calado (killa) for convincing me to go stroker with his write up
    The original guys in this scene who pioneered the stroker stuff for us
    And all the others I’ve probably missed
    -Jake and my shop is DoWerk Garage
    01' Golf 1.8T - The daily, GT2871R .64 externally gated, Tapp 630cc mafless tune, SB stage 3, Brute rods, ported AEB, 1mm over valves, CAT gold springs, Vmaxx, and countless other tidbits
    Send
    me a pm if you need work done in New England... Fabrication, engine builds, timing belts, brakes, ect
    Oct 27 2007
    Westerly RI
    Re: Official Displacement Increasing Thread
    reserving this spot for additions which im sure will be needed
    Quote Originally Posted by 317ssayzarc _update 3-22-08
    i need these pics added onto the post that i reserved in my engine build sticky... plus on the original post i need the 6.4mm changed to 3.2mm, mistake on my part lol...
    Send
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    Quote Originally Posted by 317ssayzarc View Post
    Write up looks dead on
    keep on
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    a bunch of crap
    Ocean Shitty Maryland
    now this is the stuff the community needs. great work. looks like AZ is turning the corner.
    The harder I practice, the luckier I get.
    - Gary Player
    Veteran Member Three Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    looks like i'll be running the 92.8mm stroke crank with the 83mm bore "next" time....
    what is a better block to do this with? 058 or 06a?
    thanks
    josh
    -josh
    98 AEB 1.8t Laser Red
    garage parked again.......
    v-band 3071r on the way
    APR Stg 3 for AEB engine for sale
    will include cat back exhaust, DP, and intercooler setup
    Link
    Jun 04 2004
    fairfield cnty, CT
    How does compression ratio figure into all of this?
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I thought you said this was going to take a week Jake.
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by Beemer832 View Post
    thanks
    josh
    06A but the accessories are different... It's really too much of a pain to convert it, just do it with your 058, it was no big deal for me to clearence the rods
    Send
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i would have, but I am already in deep with rods, pistons, and so forth. i just want to get my car back on the road. the next engine I build will go with the new crank and better rods and pistons.. the twin scroll manifold mike mentioned sounds pretty taunting.. maybe that engine can go into my a4 racecar i always wanted to build.....
    -josh
    -josh
    Link
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by ModifiedA4 View Post
    I could get all into the physics of compression ratios but heres and easy way to understand it...
    PROS
    Higher CR:
    More power off boost
    Less lag
    Lower CR:
    More boost on pump gas
    More timing
    CONS
    Higher CR:
    Less power in boost
    Less boost on pump gas
    Lower CR:
    More lag
    Lower vacuum to an extent
    Send
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by killa View Post
    keep on
    Thank you Paul
    Send
    Veteran Member Four Rings Nebone's Avatar
    2005.5 Audi A4 2.0T Avant
    Cumberland, RI
    These engine build threads just keep coming. They should be stickied so no search is needed. I guess you forgot about my brakes Jake and had this eaxtra time to write this thread. :)
    Oct 27 2007
    Westerly RI
    I wrote it in an hour between 1-2 AM Sebastain!
    Take it easy! Try greasing em up first, save me some valuable time to build my motor!
    Send
    Jun 04 2004
    fairfield cnty, CT
    PROS
    Higher CR:
    Less lag
    Lower CR:
    More timing
    CONS
    Higher CR:
    Less power in boost
    Lower CR:
    More lag
    thanks!
    It seems like for people who like to drive turbos, LCR is mo'betta. Though maybe a tracked car would favor a HCR.
    Oct 27 2007
    Westerly RI
    thanks!
    Depends on what kind of track... You typically would use a lower CR for dragging and a higher CR for road racing
    Send
    Cumberland, RI
    I predict your motor will be mint. Info here is great. Running more boost with LCR would definitely benefit 1/4 mile races.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Im glad all the coil pack and intake threads are being replaced with engine building threads and new turbo options. keep up the good work fellas
    2000 Audi A4 1.8TQM
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Dec 14 2005
    Quote Originally Posted by 94jedi View Post
    so does that mean your getting an a4 again?!?
    2000 Audi A4 1.8TQM
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    good stuff, I wish I had this list when I was doing mine
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    thanks!
    Really depends on the user and what he feels like putting in his gas tank.
    Most people favour lower CR because if you were on a High Compression Ratio then a tank fulled with race gas every week WILL BREAK YOU.Lower CR is more forgiving to "your mistakes".
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
    New Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    Wow i was under the impression that the 06a block had to be clearanced for the rods as well with the 2.0 crank
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    Oct 27 2007
    Westerly RI
    nope
    Send
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    I presume the AMU block (225hp TT) is also an 06a..?
    If so, then it'll bolt up in the B5/B6 A4 chassis longitudinal. Correct?
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Oct 27 2007
    Westerly RI
    its 06a and the only difference is the webbing on the side of the block, nothing to worry about for any swap what so ever
    Send
    Dec 03 2005
    connecticut
    Thanks for the info!
    -Doug
    Sep 23 2006
    Jersey
    Not all 058's need block shaving, the 9A for example is already a bubble block and will not require any grinding.
    Bad Ass I Beam rods are finally here. Join the Brute Revolution
    My Car is for sale, click here:http://www.audizine.com/classifieds/...?product=39888
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    What cars had a 9A bubble block?
    BetaAlphaTau Member #40
    2.0 3071r wire tucked
    ~Brenden
    If you need any work done in CFL shoot me a pm. I do it all.
    TAPP tune/intake for sale.
    Feb 26 2006
    Earth
    Quote Originally Posted by t1demont1 View Post
    All 2.0 16V B3 Passat, MKII Golf & Jetta.
    Block is nice but not worth it compared to the 058 AEB.It does not have the 2 oil returns @ the rear of the block.If you are going through that much trouble for a bubble block then go ABA.
    Active Member Two Rings pja0750's Avatar
    Jan 25 2007
    B5 A4 1.8T, 56 Ford Customline
    plymouth, minnesota
    how much do you need to grind the IM shaft away? im doing this build right now and im taking it to the machine shop tomorrow so im trying to get all the specs i need to tell him. if someone knows all the specs to change the AEB to 2.0 just pm or post on here
    Pat
    B5 A4 1.8TQ, soon to be BAT set up
    Account Terminated Two Rings
    Aug 22 2009
    Riverside, CA
    great sources here
    New Member One Ring
    Jul 26 2009
    bc canada
    I'm in the process of doing an 058 stroker and I had a real hard time finding this info so i thought i'd post it up.
    For the 058 you will also need new IM shaft bearings, a new pilot bearing to press into the end of the ABA crank "manual trans." and the sleeve and bushing for the oil pump should also be replaced.
    IM shaft bearings- part #056198521 (cannot be bought from the dealership as far as i know without buying a new IM shaft but can be found online)
    Pilot bearing- part #056105313C
    Bushing- part #056103541
    Sleeve- part #053115167
