Page 6 of 6 FirstFirst ... 456
Results 201 to 210 of 210
  1. #201
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Re: Time for another GTRS build thread!
    Quote Originally Posted by jbrown7815 View Post
    How much money did you invest to just do rods & the rest of the stuff required to do them? Did you pay labor?
    I would expect to pay $1k-$1500
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  2. #202
    Senior Member Four Rings B6Lovin's Avatar
    Jun 29 2007
    2003 A4 1.8TQM 3076R
    Cary, NC
    thank you clint
    Audizine's Quickest/Fastest 1.8L B6 A4 (lol)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
  3. #203
    Senior Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    03 Audi A4 1.8T Quattro 5 spd
    Clovis, NM; Cannon AFB
    Quote Originally Posted by B6Lovin View Post
    well that's the problem - i didn't do JUST rods. i've got a totally built motor because i didn't do JUST rods the first time and i blew up my engine.
    yes i payed labor for my motor - everything all said and done stayed around upper 9g's counting all labor, built bottom end, head, new turbo, lines, intake mani/TB, exhaust mani, etc etc etc. everything in my engine is new other than the intake valves, cams, and crank. (block too, but it was supposedly a low-miles block, and it was honed anywho.)
    ill send you a PM regarding this and a few other things tonight
    Sounds great, thanks!
    Southbend | Neuspeed | Koni
  4. #204
    Apr 08 2009
    Connecticut
    okay. so i have read this thread back and forth from page 1. earlier in the post some mentioned about the boost valve on the turbo that connects to the n75, or the boost controller. The GTRS does not have this boost valve, and some stated that the boost valve is located on the turbo outlet adapter flange?? what part is this? does it come with the eurocode kit? I need help with my set up so please if someone could help. thanks.
  5. #205
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Quote Originally Posted by dubgli View Post
    Its either going to be on the output flange of the compressor (a barbed fitting) or you are going to have to drill and tap either the output flange or your charge pipe to your intercooler.
    I don't see it on the output flange here (lower left corner of the turbo) so I presume you are on your own to drill and tap.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  6. #206
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM AVANT, 2004 audi a4 1.8t -RIP
    Vermont, usa
    GTRS comes drilled and tapped on the charge pipe, at least from eurocode it does.
    OEM '05 USP 1.8TQM 6-er Avant with too many parts to list
  7. #207
    Dec 03 2005
    connecticut
    Quote Originally Posted by Molotov View Post
    Thanks for the clarification. I've only dealt with used GTRS' that already had the fitting installed. Was not sure what a new GTRS comes with.
    -Doug
  8. #208
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    ^^mine has a fitting.
    USP CLUB MEMBER #71 BetaAlphaTau Member #16
    tumblr
  9. #209
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    My gtrs had a nipple on it for the boost reference line as well when I bought it back in Dec. 05
    It is on the inside of the outlet of the turbo closest to the center cartridge. That is why you cant see it in that pic.
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
  10. #210
    Active Member Two Rings GypsySmash's Avatar
    Jan 04 2010
    boulder CO
    another thing....
    Do a compression and leak-down test prior to installing any of your GTRS hardware. I would advise against installing the GTRS if your engine isn't sound. Trust me......
    How can I know or make sure that my engine is sound? and what can I do to make sure that it IS in sound shape
