Results 1 to 9 of 9
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Magnetic block heater?
    Well the snow and cold weather is finally here and it will soon be cold enough that the car won't wanna start. I'm thinking of getting a magnetic block heater, I have a V6 so it would be fairly easy to throw it on and remove it when needed. Anyone had any experience with these? I'm wondering if they work pretty well or not. Or would I be better off just having a shop put a normal block heater in, and how much do you think that would cost? Thanx
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Magnetic block heater?
    Quote Originally Posted by generik777 View Post
    got a link?
    Active Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    How cold does it get over there? Even when it is below zero my car starts just fine. A good battery helps. Both the Audi and Subaru run Optima red tops.
    Jim
    I Do Werk.
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    wont work on the audi, oil pan is aluminum.
    Mar 09 2004
    nw michigan.
    FWIW, my Outback has a block heater. It hasn't ever been plugged in. The right weight oil is important.
    Jim
    I Do Werk.
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    I've only had mine not start due to cold twice - one time its was at -25 below, there was a strong wind and I parked it so the wind was blowing directing into the front of the car. The other time I think it was a bit colder -30 or so, at that was at the inlaw's - yeah that looked great. Both times I went and got the battery checked and it tested good. Just too dam cold!
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Established Member Two Rings Kunundrum's Avatar
    Sep 30 2006
    99.5 A4 1.8TQMS / 2009 GLI 6sp
    Pickering Ont.
    0w40 synthetic is what I use in January to March, never had a problem and was in -30 a couple times.
    ***99.5 A4 1.8TQMS***
    1.0Bar Neuspeed Chip, 6000k HID, 710N, Stage 3 SouthBend OFE, 18" CSA (BBS Clones) on PZeros
    ***2009 GLI 6spd***
    May 12 2007
    MN
    Quote Originally Posted by akielb View Post
    Yeah same here, Last year it was around -40 with the wind chill and the car didn't want to start. I also had my battery tested last year and it was all good. I pretty much just wanted it for those nights where it gets extremely cold.
    Established Member Two Rings mark_2328's Avatar
    Apr 04 2007
    Fargo, ND / Brainerd, MN
    I'm in minnesota and my car REALLY struggles to start now that its getting somewhat cold. 20's, 10's, etc. What's the best weight oil to run in the cold north winters?
