After getting tired of using the seatbelt to strap the car seat in i broke down.
I ordered the parts needed to make the s4 LATCH compatiable.
Parts needed were:
8d0813545 Left bracket
8d0813546A Right Bracket
8L0019233 Plastic guides for the belt (not really needed)
8L0837453 Bolts 4 total needed.
If your lucky you can get the "kit" which has the bracket, bolts and guides, they are discontinued from the dealer but if you can find one they are only around $8 for the complete side.
I was lucky enough to find one side Part numbers are ZAW269004 and 005. (thats why one set of bolts are of different color)
If not it will run you about $50 in parts for a side.
I put the seat in the center so i needed both sides.
Install was super straight forward, just remove the bottom coushion, remove the upper seats.
Bolt the brackets in with the bolts to 22ft-lbs into the factory holes (yes there are already holes that are threaded and ready to go), re-install the seats.
The brackets fit very nicely, does not preven the seats from folding.
You cannot see the brackets at all once they are installed, and you cannot feel them if you sit in the seat.
I believe you can take the brackets to the stealership and they are obligated to install them at no charge.
