With the air lines run and ready to go, I was ready to finish installing all the air management components. The first thing I had to do was create the wiring harness for the air management system. This got a little confusing considering that each valve has six wires going to it. Here is a shot of my living room in the middle of the day as I was laying everything out:
My roommate walked in the room and commented that if he didn't know what I was building, he would think I was assembling a bomb in the living room! LOL
Here is a shot of the harness as I was working on finishing it up:
The gold things on top of the valves are the sending units for the gauges.
After I finished the wiring harness, I put the tank together. Depending on how you put your setup together, the parts you use for this will vary. However,
ALWAYS use DOT approved air fittings and air line on your car! I got my fittings locally from a place called Valley Hose and Fitting in Kent.
Make sure you use Loctite 545 (the red stuff) on all the fittings to ensure an airtight seal. You don't need a lot of the stuff, just a drop on each piece is all you need. Another thing to keep in mind while tightening air fittings is that they are
really hard to tighthen! They're not like a regular bolt where you can easily turn them until the end. After the first couple of turns. it gets really difficult to turn these fittings. It's also normal to not be able to tighten them all the way down, so threads will still show once it's tightened.
Once everything was mounted, it was time to turn the enclosure on its side and mount the relay for the air compressor and the block that supplies power to everything that needs a connection to constant 12v power (the switchbox, wireless controller and compressor relay). You're looking at the bottom of the enclosure in this pic:
The red wires are the leads for the gauge senders, the green wires come from the pressure switch on the tank which turns the compressor on, the black wires are the ground wires for the valves and the red and black wires twisted together are the leads from the compressor.
After this, it was time to manuever the whole setup into the car. The completed enclosure isn't particularly light and it's pretty awkward to move around, so it took a little work to get it into the car, but it made it without too much of an issue.
After I got the air management into the trunk, I had to run the air lines to the valves and connect the wires to their proper mate on the wiring harness I made and installed in the car a couple weeks ago.
This is before I cleaned up the wires and finished connecting everything:
After everything was connected, I started the car and the compressor kicked on, ran for about two and half minutes and turned off at 150psi. This was Sunday evening, and now two and half days later the compressor still hasn't kicked back on, so I'm pretty happy to report that I have NO air leaks in the tank!
I still need to finish hooking up the valve leads to the control box for the switches and clean up the wires a little, but other than that, I'm pretty much done with the air management.
The white square on the wall of the box is where the receiver for my remote control for the switches will mount. The carpet actually matches really well also, but since the OEM trunk carpet and the aftermarket stuff I have aren't exactly the same material, they reflect light differently so it doesn't look as good in pictures. In person it's a really close match though.
Next up:
installing the suspension!
I plan on having everything installed and working by Friday evening.
