    Senior Member Three Rings gunxit's Avatar
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    B7 Door panel removal
    Hey guys,
    I'm trying to remove one of the front door panels.
    So far, I removed the 4 screws behind the trim and a 5th screw at the bottom.
    After that, just pull out and push up?
    Is that it? I just want to make sure before I break anything.
    TIA
    Veteran Member Three Rings TSlice's Avatar
    May 18 2007
    Houston
    Re: B7 Door panel removal
    Yes, just get your fingers or something slim between the actual door and the door panel (I think I did this at the bottom of the door panel) and pull sharply. You will probably break a few of the clips that hold the door on in the process, so have a few replacements handy. Then you just lift the panel up and over the lip at the bottom of the window glass. Make sure you have disconnected the door handle cable and all electrical connections before completely removing the panel.
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Quote Originally Posted by TSlice View Post
    Your instructions are correct for the front passanger side door panel. Forgot to mention I was removing the driver side panel.
    As for the driver side, there are 2 more screws right behind the handle. Just gotta remove the cover. So it'd be 5 screws on the front/right panel and 7 on the front/left.
    Once all screws are removed, pull from under and push up. EZ.
    Hopefully this helps a fellow B7 member in the future
    Veteran Member Three Rings Kyokio's Avatar
    Dec 28 2005
    2006 Audi S4
    NY/NJ
    Hey,
    A little ot but I was wondering if there is a way just to remove the bottom panel of the driver side door (ie. ie the area that has the trunk and gas cap buttons).
    TIA!
    Current ride:
    2006 Audi S4 - DTM
    Previous Rides:
    2003 BMW M3
    1999 Lexus SC300
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2011 Q5 2.0T PremPlus
    Wayne, NJ
    hey Kyokio..do you have any pics of your car from the side with your 35% tint..i am planning on going 35%..i had 15% on my B6 and 20% on my other B6, but i want something a little lighter now..thanks!
    2011 Q5 2.0T -Prem.Plus Black/Beige <<<Wife's car
    2005 S4 Black/Black&White Alcantara|19" BBS CH|245/35/19|ST CO|FI Catback <<<Daily Driver
    2009 C63 AMG Black/Black |Kleemann K1|K&N Filters=500+ HP <SOLD
    ::12.2@ 116:: on stock tires!
