Page 2 of 2 FirstFirst 12
Results 41 to 72 of 72
  1. #41
    Senior Member Three Rings rams456's Avatar
    Jan 05 2008
    Audi A4
    Bay Area
    Re: Common B7 A4 Problems/Issues & Solutions
    Quote Originally Posted by Jersey Stephen View Post
    woow are cars are build like shit
    then why did you buy one???
    if you want a car thats reliable go buy a honda
    2008 Audi A4 6 Speed Manual, Quattro, Titanium Package, S-Line, Debadged, Boost Gauge, RS4 Sway Bar, Front Plate Delete, Stasis Exhaust, JHM "Extra" Short Shift Kit, Stasis K04, 034 HFC
    rawd farva=xbox live gamertag
  2. #42
    Senior Member Four Rings Sharkfin's Avatar
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    I am going to the dealer today to get some of these issues looked at before my factory warranty runs out soon, thanks to the OP!
    Past: DTM 2005.5 B7 A4 2.0TQT
    Current: 2008 Infiniti G37s Coupe
    Future (2012-13): A5, S5, S4
  3. #43
    Active Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    awesome write up!!!!
  4. #44
    Jan 13 2009
    Pacific Northwest, USA
    Images have gone missing as of Jan 09...
    Any chance of getting them back?
    Thanks for the write-up
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
  5. #45
    Senior Member Four Rings chaze's Avatar
    Sep 16 2007
    2001 A4 Avant, 2009 328i
    Canyon Hills, CA
    I thought somebody mentioned this before, but I've done some mild searching, and haven't come across anything yet.
    Has anybody experienced what happened to me twice today... in that my sunroof "tilt-up" MOVED without me being anywhere near the controls??
    I was driving and crossed an elongated speed bump, heard the sunroof motor and noticed it had opened about halfway. It later twitched again driving on smooth road.
    I wouldn't be paranoid if I hadn't recently found out that when my car was CPO'd, the only thing that was replaced was the sunroof mechanism.
    Any tips guys?
    -Chris
    2001 A4 Avant - Apr '11 to Present
    2008 A4 Sedan - In the graveyard
  6. #46
    Sep 16 2007
    Canyon Hills, CA
    Quote Originally Posted by chaze View Post
    Any tips guys?
    Edit: had it fixed under warranty. Bad potentiometer in the dial.
    {bump}
    Last edited by chaze; 03-09-2009 at 05:30 PM. Reason: found the solution. Does anybody read this thread?
    -Chris
  7. #47
    Senior Member Four Rings viperdsa's Avatar
    Aug 28 2007
    '06 Dolphin Gray A4 2.0T
    west of the equator
    wrong thread
    2006 Dolphin Gray A4 2.0T Quattro
  8. #48
    Jan 20 2008
    Patchogue
    I was having all the symptoms of Cam Lobe wear. It haven't been able to get it to do it in about 4 to 6 months and since the soft codes have disappeared. Unfortunately the warranty is over in 15,000! Hope it throws some codes so I can get it fixed before.
    Is there another fuel pump available that would have greater reach to the Lobe or is the only solution to replace the Cam.
    Also, just had to have my PVC changed by Audi...
  9. #49
    Senior Member Three Rings Slovak84's Avatar
    May 26 2009
    2009 B8 A5 3.2L Quattro
    New York
    Did anybody have any issues with the Timing belt in a 2008 A4 (B7) 2.0T?
    Last week I noticed a belt was squeeling after cold start but the noise was gone like 5 minutes later. The squeel was not to bad but annoying enough, I took it in to the dealer and they said they replaced the timing belt (Under Warranty) is the service manager bull shitting? the Car has 19,000 miles and is not pushed or abused !
  10. #50
    Veteran Member Four Rings Jer's Avatar
    Sep 17 2004
    Supra, Tundra & A6
    Colorado, USA
    Either they told you wrong or you heard wrong because a timing belt won't squeel unless it's a tensioner or something but there's little to no drag on a tensioner so if it failed it could but that's the part that would need replaced, not the t-belt. It would have to be an accesory belt.
    Quote Originally Posted by Slovak84 View Post
    Belt won't Last week I noticed a belt was squeeling after cold start but the noise was gone like 5 minutes later. The squeel was not to bad but annoying enough, I took it in to the dealer and they said they replaced the timing belt (Under Warranty) is the service manager bull shitting? the Car has 19,000 miles and is not pushed or abused !
    2004 Chevy Silverado SS AWD
    2007 Audi A4 2.0T Quattro
    2007 Toyota Camry Hybrid
    2007 Suzuki GSX-R1000
    =-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
  11. #51
    Senior Member Two Rings prospero's Avatar
    Apr 13 2009
    Denver
    Can someone update information regarding:
    a) DV - please update to new revision (Upgraded OEM Diverter Valve, Electronic (06H 145 710 D)
    b) Timing Belt issues?
    c) Dipped headlamp issues...
    d) PCV fix? (new kit by BSH - http://www.shop.gngmotorsports.net/p...&productId=171)
    current // 06 a4 2.0t quattro 6sp | brilliant black | dtm rear lip | euro cupra front lip | K&N | greddy tt | hoen xenonmatch fogs | vag'd' | 30% tint
    soon // unitronic stage 1 | rs4 rear sway | oem rev 'D' dv | awe vent boost gauge
  12. #52
    New Member Two Rings
    Apr 14 2009
    Hacienda Heights, CA
    so i have a b6 but im forced to sell it because of so many issues and without warranty i cant afford to fix them...
    im lookin into to a b7 either 06' 07', so is there a good mileage to get these at?im goin for as low as possible, do most of these problems generally occur within the warranty period?
    just trying to get as much info as possible so i dont want a repeat, thanks
  13. #53
    Senior Member Four Rings groundround's Avatar
    Jun 19 2009
    07 a4 2.0T S-line TI pack
    somerville ma
    Have had the crankcase ventilation valve go on me and it was many trips back to the dealer and headaches for them to actually find out the problem was the crankcase ventilation valve. My car would idle up and down from almost stalling to 3000 RPM's, and was out of warranty when they finally found out the problem.
    I lost it on the service guy and exploded right there on the spot and they ended up doing it for free :)
  14. #54
    Sep 16 2007
    Canyon Hills, CA
    Quote Originally Posted by groundround View Post
    I just had this replaced at 25k miles. Did your car shudder hardly at startup?
    -Chris
  15. #55
    New Member One Ring moedog's Avatar
    Jun 18 2009
    2006 A4 2.0T Quattro
    Denver
    Great Post...
    2006 A4 B7 2.0T
    I have a cylinder 1 missfire ... i swapped plugs n coil packs to see if missfire follows (separately of course). It didnt so I replaced the injector, but I still have the misfire! someone plz help!!!
    "Drive it like u stole it!"
  16. #56
    Senior Member Four Rings Hyphy's Avatar
    Jan 09 2009
    Ft. Lauderdale
    Add this if you don't mind:
    Official Cam follower thread:
    http://www.audizine.com/forum/showthread.php?t=295208
    Nick
    PM me if you need any B5 work done in south Florida.
    I'd rather be flying
  17. #57
    Senior Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Any way to get the pics re-uploaded? Thanks!
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
  18. #58
    Senior Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    Quote Originally Posted by moedog View Post
    Great Post...
    2006 A4 B7 2.0T
    Need to use Vag-com to pull the codes. Got MIL?
  19. #59
    Senior Member Three Rings CX-7&A4's Avatar
    Dec 08 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    What about the CVT oil line tearing.. I had this problem and a few others as well.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
  20. #60
    New Member One Ring
    Sep 23 2009
    Minnesota
    What can you say about the smell of cat urine in an A4? 4 Days after we brought it home it started. Whole garage smells from it. Inside the car it is very strong odor.
  21. #61
    Mar 17 2009
    Boston, MA
    Quote Originally Posted by allworldauto View Post
    I can say that it can be pretty bad. Replace the cabin filter and run the heater with fan on. You've got some serious mold issue in the vent ducts. You can use foggers or an ozone machine to circulate odor neutralizers in the car as well if replacing the filter does not help.
  22. #62
    Jun 20 2008
    Vancouver
    Re: Those common problems (Good read)
    7. Tumble flap failure
    Quote:
    Background:
    The tumble flap motor is prone to failure. This is probably the most common problem I’ve seen when scanning cars with the vag-com. A little background on how the tumble flap works:
    Quote:
    Symptoms:
    You may see the following DTC’s
    -012599 - Intake Manifold Runner Control: Basic Setting not Completed
    P3137 - 001 - Upper Limit Exceeded - Intermittent
    -008196 - Intake Manifold Flap; Bank 1: Stuck Open
    P2004 - 008 - Implausible Signal - Intermittent
    - 012600 - Intake Manifold Runner Control: Regulation Deviation
    P3138 - 008 - Implausible Signal - MIL ON
    Solution: The intake manifold flap motor needs to be replaced.
    anyone knows if this causes a rough start? my car was shaking while starting up but runs completely fine.... (at least on the 5 km trip to the dealer). The dealer told me it is something about the intake manifold... so i am guess it's this problem....
  23. #63
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    Quote Originally Posted by prospero View Post
    +1
    any solutions to this? the dealer replaced the headlights and ballasts, and though they don't go out as much as they did, the left side still goes out every so often.
    The dude that loves cars with character: raw, rambunctious road manners, angry triangles and four devilish rings ...
  24. #64
    Jan 09 2008
    '06 A4 2.0TQ Tip
    Crystal Lake, IL
    Quote Originally Posted by diabolical1 View Post
    +1
    Don't have a fix, but when I mentioned this to my dealer they claimed it could be a software issue...? Can't remember now what exactly needed to be updated, but I do remember that they wanted $200 to "maybe fix the problem". This has become a big annoyance for me, now both sides flicker on and off.
  25. #65
    Aug 18 2009
    la
    Quote Originally Posted by joseb View Post
    very annoying and dangerous. Cant we file a class action lawsuit for Audi to resolve this problem. Sometimes both my headlight will go out at the same time.
  26. #66
    Jan 09 2008
    '06 A4 2.0TQ Tip
    Crystal Lake, IL
    Quote Originally Posted by xcuter View Post
    Actually, my car is sitting in an Audi service bay this very minute for this issue. I set up the appointment and told them the problem, along with mentioning this TSB: Dipped Headlight TSB
    And they agreed that it was a problem. No word on what they'll do to fix it, or if they'll fix it at all. I'll report back later after I pick her up.
  27. #67
    Jan 09 2008
    '06 A4 2.0TQ Tip
    Crystal Lake, IL
    Well, the car was at the dealership all day Wednesday and they couldn't reproduce the issue. They gave the car back but I haven't had it happen to me since then. They recommended leaving the car there for a few days this week, so it's going back to them on Wednesday for a few days. Again, I'll let you guys know if I hear anything.
  28. #68
    Senior Member Three Rings ChampionV63.2's Avatar
    Jan 28 2009
    C230 Kompressor
    SOUTH FLORIDA
    I have the same problem and it has already been fixed once and they changed the xenon bulbs at that time as well. I am told they will not do the bulbs again...i have the pay this time.
    Also, do any of these issues apply to the 3.2 besides the a/c?
    Chip/Custom Cat-back Exhaust w 2.25" piping w/ x-pipe and Thermal R&D mufflers/Stasis Coilovers/RS4 Sway/VMR V718's/15%Tint/Phantom Black Front Filler, Grille and Rear Diffuser/LED License Plate and Interior/CC Mod/Ziza City Lights/Ziza Yellow Fogs/Spoiler/Vag'd/S4 Mirrors/Carbon/K&N Drop In/Pioneer AVIC X120BT/Alpine REF 6.5 Components//JL Audio W6/JL 550.1 & 300.4/JL ZR Components/Laminix tails, etc...My Car is For Sale, Check the Classifieds
  29. #69
    Senior Member Three Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT
    Portland, OR
    Is there anyway to get the pictures rehosted on a site that works? I can host them on my school site if needed.
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
  30. #70
    Jan 09 2008
    '06 A4 2.0TQ Tip
    Crystal Lake, IL
    Sorry for the long delay in posts, the car came back from the dealer back in November and I have not had the headlight issue since then.
  31. #71
    Jan 16 2008
    bosnia and herzegovina
    Hi, can I ask you please to investigate, what did the dealer do?! Did they replace something or just made a software update?
    I have the same problem with my 2006 b7 and my bi-xenon lights. It flickers and goes off all the time... I think most of us have the same issues with their head lamps so it would be great to share your expirience with us.
    Thanks
    Omar
  32. #72
    Jan 09 2008
    '06 A4 2.0TQ Tip
    Crystal Lake, IL
    Quote Originally Posted by bullomar View Post
    Thanks
    Omar
    Well the dealer ended up replacing both lights under the extended warranty. A different dealer wanted to try flashing some software but also wanted $150 for their effort and weren't sure that it would even help.
