Senior Member
Three Rings
Re: All your Blow Off Valve (BOV) & Diverter Valve (DV) / By-Pass Valve (BPV) Questio
 Originally Posted by S-Power
sorry, so its not possible to put a BOV on the s4 b5 correct? or it is possible but its does harm ?
You can, however it's not recommended.
Those of you looking for the BOV sound, this is what I recommend. Purchase the inexpensive and reliable 710N DV's and an EVOMS CAI. You'll end up spending less than you would for some expensive forged DV's or "hybrid" valves and you'll get the sound that you're wanting.
That's just my .02 cents.
2002 Audi A6 2.7T --> Stage II+
Four Rings
do you know how it sounds with that on it? is it like a gti wit a BOV or something, can u relate it to anything? i cant find any vids wit a bov on an s4 i guess nobody puts them on.
Senior Member
Three Rings
Hey buddy,
I'll try to make a quick clip of it, I have the setup that I spoke of above on my A6 (2.7T).
Account Terminated
Two Rings
get bailey's i know they are pricy but once i bought them i dont regret it at all. and for those of you running it i compare it to the apr bi-pipe its one of those things that kind of expensive but SOOOO worth it when you buy it and install it. plus you will never have to do the mod again. i know somebody who blew a 007 with 24 psi but that was just one instance, ive just heard of it being impossible to blow baileys
Registered Member
Four Rings
it's probably because he had the wrong spring in there if it was a 007A.
'07 S4 Avant - The Purpetrator
there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
Senior Member
Three Rings
Does anyone know if the turbosmart hybrid BOV/Diverter works on a b5 s4? i talked to someone and they couldnt fit them on, and if thats so that means no hybrids will work. can someone clarify this for me. thanks
Forum Moderator
Four Rings
I don't believe they will fit without an adapter, which i'm not sure if anyone makes.
The Forge "Splitter" valve will fit our cars, and can be adjusted between DV and BOV.
--Adam
Senior Member
Three Rings
can the forge splitter be adjusted to 100% bov or vice versa? Im looking at the GFB stealth adjustables. How do those tend to work?
Forum Moderator
Four Rings
I don't know if the Forge can be adjusted to 100%. I would assume so. Try PM Pat@Forge and asking him.
--Adam
Forum Moderator
Four Rings
Also, I don't know anything about the GFB's.
--Adam
Senior Member
Three Rings
My buddy has a GFB on his A4, but im not sure if they would bolt up to the S4 without any adapters and what not. any input on this?
Four Rings
cant i put 007 DV and then get an open cone filter and it would make the pshhh sound right? or im wrong ? cuz on my GTI 1.8T i had that and it made pretty loud pshhhh
Forum Moderator
Four Rings
Yes, you are correct. Though, it will be quieter on the 2.7T.
--Adam
Forum Moderator
Four Rings
I would assume it will need an adapter, but every DV/BOV is different. Sorry, I can't be of help!
--Adam
Four Rings
--Adam
Will it be noticeable at all or just when really close ?
Forum Moderator
Four Rings
To me personally, it's not noticeable unless you're paying attention inside the car or if you're outside the car.
But, im coming from the turbo world where the louder the BOV, the better.
Meaning, i'm used the really loud sequential BOV's. There is no sound the S4 can make that remotely compares to a real BOV, in my opinion.
If the 1.8T is a 5 on the loud scale, the 2.7T is a 2.
--Adam
Four Rings
so theres really no way to have it like a loud BOV correct ?
Active Member
Two Rings
so it would be a bad idea to run two hks ssq's?
Senior Member
Two Rings
yeah not the best idea
01 S4 -James-
2001.5, 6 speed
Darintake, 710N, Samco TTB
GIAC X
clutchmasters stage 4 and LW flywheel
K04's ...there screaming
piggies, ssac catback
Forum Moderator
Four Rings
You can try the Forge Splitters. That would be the closest thing without actually running BOVs.
--Adam
Senior Member
Three Rings
you would run rich by not using diverter valves
Forum Moderator
Four Rings
One person did run them sucessfully, I believe. But he's not around anymore, I don't think. I would say 9 times out of 10 it will end up causing problems.
--Adam
Active Member
Two Rings
but it sounds awesome what do you do to get that
Forum Moderator
Four Rings
What do you do to get what?
--Adam
Active Member
Two Rings
can you not have any bov sound is what im asking the rmm pssh
Four Rings
hahahahahahahahahahahaha
ricer.
"Fazz" | Interactive Web & Application Developer | www.pixelpandas.com
2008 RS4 Exclusive/Premium - Unitronic Tuned | Milltek non-res catback | XS 2.5" catless downpipes | 19x10 Rotiform SNA | K&N drop-in | 034 MAF hose | JHM LW rotors | 20% tint | DTM Carbon front splitter | DTH carbon engine cover | Gallardo flat bottom wheel | LED taillights | Black Optic Grille | Black e-codes | JHM IM spacers
Forum Moderator
Four Rings
Can you not have the sound? Yeah, by a DV.
You want the sound? Use the splitters at your own risk.
--Adam
Active Member
Two Rings
ricer.
haha thats a joke we play on my friend bc he has an sti with ssq. i on the other hand have an m3 not much on the ricers. but, i thought ssq sounded good, maybe not on an s4?
Senior Member
Three Rings
Hmmm, has anyone anyone ever heard of a BOV-erection: http://www.youtube.com/watch?v=i4p31...eature=related
Active Member
Two Rings
 Originally Posted by Unispeed
kind of what i was refering to, he had the sti took this girl for a ride having heard his ssq he got some that night
Forum Moderator
Four Rings
It's not that it doesn't sound good, it's just that it's very unhealthy for the car.
--Adam
Active Member
Two Rings
haha alright well how about this hpf(horse power freaks) have some rediculous power out there and i dont think they would recommend something bad and they have this..
http://www.horsepowerfreaks.com/perf...Off_Valve_Kits
Forum Moderator
Four Rings
^ Looks great, but you'll have to run it at 100% closed and then you've got yourself a really expensive DV.
--Adam
Active Member
Two Rings
yea, im wanting to get an s4 im just wondering what the deal with these dv's are whats the main concept about all of this
Registered Member
Four Rings
I'm going to be giving the Forge Splitters a whirl.. I'll do a writeup on them. just gotta work a little more to get some $$ in da bank
Forum Moderator
Four Rings
Read the first page of the sticky and your questions will be answered :) If not, come back and ask, and we'll help you out!
--Adam
Forum Moderator
Four Rings
Nice  Let us know! I'm sure there are many that will be interested.
--Adam
Active Member
Two Rings
another quick question if you ran dual ssq's and recirced them would there be a problem
Senior Member
Three Rings
reading through this thread, I see a little talk about it but nobody actually running splitters. I've got one on my TT that works flawlessly and I'm getting my S4 next week so I will be putting splitters on it.
1985 Audi coupe GT 2000 Audi S4 IY SP/alcantara stage 2+ 2008 BMW 135i M-sport
Forum Moderator
Four Rings
Most say there will, but so few have tried it, I can't say for certain. I only know of 1 person that sucessfully ran them. They are tech. never a fully circulated valve, as they still "blow-off air".
--Adam
- You may not post replies
- You may not edit your posts
Forum Rules
