Active Member
Two Rings
01 B5 S4 2.7 Bi-WINNING!
I
Active Member
Two Rings
RandyQUATTRO = Randy
no, really!
New Member
One Ring
Active Member
Two Rings
Sleepwalker_gsr
Daniel
Sacramento,CA
"i think you should replace the distributor and the check engine light, they only blink when the light is bad ".
Active Member
Two Rings
Forum Moderator
Four Rings
Active Member
Two Rings
cabby
Senior Member
Three Rings
Wow getting to this late...miggity02=Mike
B6 1.8t Quattro sedan - lightly modded - SOLD
B5 2.8l Avant 5mt quattro - Sport Package - JHM short shifter - K&N - Magnaflow with 2.5" piping - STs - Yak rack - 2500k fogs and highs - OEM USPs - tinted [7%/17%/35%>
2007 8P 2.0t - 6MT - S-line - Sport Package- Premium Package - Nav - (tinted)Open Sky - Cold Weather - Bose - REVO - AFE Pro Dry - Magnaflow w/resonator delete - H&R sport cup kit - Eibach 23mm RSB - Ti wheels - 10mm spacers - BFI torque mount - AG M310s
Four Rings
figure ill be out there soon enough so
<**** Nate
Four Rings
Really late getting on here
Greg Nelson
Mountain View, CA
2009 3.2L Sedan BB/Beige . VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. Modified Votex Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
Senior Member
Four Rings
Originally Posted by
Greg Nelson
Greg Nelson
Mountain View, CA
ORLY? never would've crossed my mind that was your name
jonathaN ..... Santorin 2001 s4
AWE Twin 1 Turbo-back | J-Fonz | ABD intake | Koni Sport Coilovers | Lorinser LM2 (once they are refinished) | Bailey Motorsports DV30 | Soon to be 770s Build(soon enough....)
Active Member
Two Rings
AnewMadrid=ANEW Madrid aka D.Warbux
Senior Member
Four Rings
WOW, looks like I have a ton of updating to do!
Thanks to: Lubrify.com / TOMAS Sport Tuning / BRRacing / Craftwerx Concepts / I/O Port Racing Supplies / AGUND1S Tire
Three Rings
Lucky from San Jose. Yep. Lucky.
"Kiss the rings!"
Active Member
Two Rings
new to the community and in the Bay Area - Brent
Active Member
Two Rings
Kevin...currently located in the peninsula
2009 TT 2.0T Coupe : APR Stage 1 : AWE Exhaust : KW Street Comfort Coils
Four Rings
Kevin...currently located almost in the peninsula
Four Rings
'03 Audi A4 Avant, lightly modded
My name is John.
Four Rings
Saturnine
Almost in?? haha
Santa Clara, not quite on the peninsula
Active Member
Three Rings
<**** Enrique.....from the 209.
If you listen to Movin 99.7 in the bay..Ghetto House Radio, Im Wookie..resident Dj.
Active Member
Two Rings
<**- Seth
Santa Rosa area.
My car.
Senior Member
Four Rings
So you are on here... pretty sure I spotted you a while ago Seth. Nice S4.
Active Member
Two Rings
I thought I replied to this thread before, but I guess not.
R8ted R = Ray
2006 A4 2.0T Quattro 6MT S-Line Blk on Blk |APR Stage 1| AWE Exhaust | South Bend Stage 2 Clutch | OEM S4 BBK w/ Hawk Pads | Apikol Snub |BSH PCV | RS4 RSB | OEM Rack | 20% Tint | Titanium Window Trim & Grill
Active Member
Two Rings
Mark in the 209 triangle.
Senior Member
Three Rings
2009 A4 Avant 2.0T / 18" Sport Pkg / APR / Eurocode HFIC pipe / H&R 15f/20r spacers / Stasis Sway Bar/ VAG'd
2000 S4 6sd (371 whp/417 wtq) ASP Stage 3 / ER intercoolers / ST coilovers/ 034 / ECS
Active Member
Three Rings
Austin
thanks for the idea. i started a identical thread over in the AZ/NV sub thread
Active Member
Two Rings
2008 A3 2.0T FSI
APR Stage 2, Fully Loaded ECU | Full Votex Body Kit + Exhaust Tips | S3 Intercooler | H&R Rear Sway| Front Filler Plate | Aluminum Mirror Caps | 18" Drag Wheels DR19 (w/OEM centercaps) | 20% Tint | Debadged Rear
Member # 63 of Coalition of The OEM+ Audi Owners
Four Rings
To add another A to the 3 before me:
Arthur
Active Member
Two Rings
Rollem = Will from alameda, walnut creek. B5 S4
Active Member
Two Rings
2008 Dolphin Grey S4 6MT
Mods: RS4 shift knob, RS4 E-Brake, RS4 Pedals, Hotchkis RS4 Sways, Stern Rear Endlinks
Active Member
Two Rings
Mistereed (Mr. Reed) = Marcus
Ocean Blue Pearl 2005 A4 B6 SE | 6 speed Manual | 14829 Magnaflows | K&N Filter | 30% Tint | Smoked Red/Clear Tails
1999 VW Jetta 2.0L
Active Member
Two Rings
2008 Audi A4 2.0t Quattro MT
-APR Stg 2 and Carbonio CAI -Diverter Valve 'D" revision -AWE FMIC -034 motorsports HFC, Street Density motor mounts, Track density Trans mount, Catch Can and wheel studs -JHM Short Shifter -Adams 'Drill/Drill/Slot' Rotors F&R w/ Hawk Ceramic Pads -ECS snub mount, 7mm rear spacers and Stainless Steel Brake Lines -Stasis Catback Exhaust -VMR V701 18"x8.5, Falken PT722 235/40-18 -H&R Sport Springs
Registered Member
One Ring
Mike
Fremont
Registered Member
Two Rings
Registered Member
Two Rings
Senior Member
Two Rings
Reggaemylitis=Neil
Formerly in Sac, now in South Lake Tahoe.
APR Stage II. AWE Exhaust. AWE FMIC. Forge DV. JHM Short Shifter. RS4 Rear Sway. 034 Turbo Inlet Hose.
"We're going to sodomize our vast imaginations with this pornography!" -Ignignokt
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
