Results 1 to 11 of 11
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Oil burning smell when driving...
    Ive been getting this smell all of a sudden when driving around town in my car. After a little while it goes away, but it keeps coming back everyday. I checked my oil filter and plug (zero signs of a leak). I also checked both valve covers for noticeable leaks and still nothing. The oil level in the car hasn't changed either which is weird, i figured if their was a leak id notice it go down a bit. Side note, boost levels on the car seem normal when i get on it but the car does feel a little sluggish cruising 50 or below.
    So if anyone here could send me in the right direction to track this burnt oil smell down please let me know.
    thanks!
    Ant
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Three Rings elijahallen's Avatar
    Nov 12 2006
    2011 B8 S4, 2008 Cayenne S
    Michigan
    Items for Sale
    Re: Oil burning smell when driving...
    Have someone follow you and make sure there is no smoke coming from your tailpipe on decel. If you do have a hint of smoke the turbo's are on their way out, this is how my K03's went and then my K04's due to coolant getting in the oil and causing sluge around the turbo bearings. The only noticable sign at first was a faint burnt oil smell when I would come to a stop at a red light or stop sign. Hope its something else but worth a check.
    Elijah
    2011 S4 giac dual pulley race file, Stage II supercharger pulley. 184mm crank pulley, AWE tuning cold front reservoir AFCO Ford GT500 double pass heat exchanger.,GIAC dual fuel pump, Autotech HPFP, USP Motorsports intake, P3 cars vent gauge, 034 stainless steel downpipes,Milltek exhaust, AEM MAP/MAF based progressive methanol injection, SPEC stage 3+ single disk clutch with new OEM flywheel,Brembo GT 380mm BBK
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    great news
    keep it coming guys!
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Jun 14 2007
    2000 S4
    Connecticut
    Items for Sale
    do you smell it constantly ??? if so im not sure what that could be maybe clutch ??? other than that if its only on hard accelleration, this happened to me, my expansion tank with coolant in it was yellow, which i didnt know was to be white, and had a very small crack in it and when under pressure, it would seep through and drip onto my headers and smell terrible! an easy way to tell is if there is pink drops running down the right side of your engine cover. that was my problem. 50 dollar tank to fix.
    Piggie Powered Stage 3 B5 S4 & 8V A3 | Videos
    Established Member Two Rings NYSTGIII's Avatar
    Dec 07 2004
    1m coupe, wrangler, a4.. and many others in the past
    Westchester, NY
    check the valve cover gaskets and cam seals for leaks. most likely the case unless there is some significant loss of power.
    Forum Moderator Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Do you still want me to delete this?
    --Adam
    Have questions? E-mail me.
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Quote Originally Posted by 1997gtx View Post
    --Adam
    no. my computer was acting up the other night and i posted the same thread 3times, lol. This one id like to keep going. There is still one more floating around i think on page 2 that you can delete.
    thanks Adam!
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Sep 14 2006
    14 GLI
    Okay, no worries.
    --Adam
    Established Member Two Rings B5swede's Avatar
    Sep 20 2006
    I had the same exact thing as AudiSportB5S4: Expansion tank cracked, cheap easy fix, but could be trouble if not detected early enough.
    Listen to Slayer.
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    yea but its more of an oil smell than a coolant smell. Coolant has that distinct smell to it that you cant confuse with burnt oil.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Jun 14 2007
    2000 S4
    Connecticut
    Items for Sale
    i guess, but i mean when i was on it, and would get the smell i thought my turbos were like catching fire i had no idea what was going on lol. the easiest way to rule this out is just look if you have any of those pink drops down the side of your engine on the right looking at it from the front. if its not there then its something else unfortunatley
