Page 3 of 3 FirstFirst 123
Results 81 to 103 of 103
  1. #81
    New Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Re: Bose Symphony Radio Controls
    In my car the key doesn't need to be in to power on the stereo.
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
  2. #82
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    this is the second time the radio safe code has saved me thanks Adam
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
  3. #83
    Registered Member One Ring thrilos5's Avatar
    Feb 03 2009
    very helpfull info
    thanks
  4. #84
    Active Member Two Rings cmagalis's Avatar
    Aug 01 2008
    2000 B5 S4 & 1997 B5 2.8Q A4
    Lakeville Mn
    Anyone know where to call to recover the code for the receiver? I lost the slip of paper with it.
  5. #85
    May 09 2009
    2000 S4, 67 Malibu, 51 Dodge
    New York
    It's common for laser players with a horizontal orientation to accumulate some dust on the laser head. Remember it's reading the bottom of the disc. Use of a mechanical brush type cleaner disc or just compressed air(get the can at Radio Shack or a PC store) to clean it will do wonders.
  6. #86
    May 09 2009
    New York
    Question Re: Bose Symphony Radio Controls
    I don't seem to have any code protection on my radio. Had this car for over a year and there is no code info with it. I have had service(timing belts, trans rebuild) where the battery was disconnected for a long period. Never had to enter any code afterwards. Is it possible to remove the code protection? Can a new code be created? Thanks
  7. #87
    Registered Member One Ring DuWerk's Avatar
    Jun 15 2008
    90 CQ. 83 Ur Q, 92 S4, 01 S4W
    Kingston NY
    I work at Shokan ( www.shokan.com)
    and we get cars in for dismantling all the time where there is no code. Our procedure is to let the radio sit unplugged for about 1 hour to be sure it doesn't remember the code and then plug it back in. That we are sure it doesn't need a code. We get a good amount of them with no code needed for operation. Some people like it because they don't have to hassle with it and for god sakes there is nobody stealing these units. We get theft S4's in all the time with the radio's intact. No thief is interested in a special built radio that doesn't fit or work in any other car.
    I believe owners chose to have the code deleted by a dealer.
    I don't think that you can re-code it without paying a dealer to do it.
    I prefer no code.
    Du Werk
    "Life is what you make it, so make it Euro and make it faster!"
  8. #88
    Active Member Two Rings rsxsty1e's Avatar
    May 25 2009
    just did the equalizer trick... sounds awesome
    thanks
  9. #89
    Active Member Two Rings TheMaverick's Avatar
    Jun 25 2009
    '05 S4 Cab; '06 Land Rover LR3
    Quote Originally Posted by rsxsty1e View Post
    thanks
    Wanted to do teh EQ trick but ... my Symphony unit does not have a P Scan button nor does it have any button labeled with a 5 on it. If I try the technique using the button that would be preset #5 when teh radio is on then nothing happens.
    Are there several different types of Symphony units?
    '05 S4 Cab | 6MT | K&N | Carbon Fiber Kit | 20% Tints | ASA ZR2 Rims
  10. #90
    Forum Moderator Four Rings 1997gtx's Avatar
    Sep 14 2006
    03 TL-S
    This is only applicable for the B5 S4 (2000-2002) radios, I believe.
    Your 05 cab probably has a different radio in it.
    --Adam
    Have questions? E-mail me.
  11. #91
    Jun 25 2009
    Quote Originally Posted by 1997gtx View Post
    --Adam
    Ah ... thanks.
  12. #92
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 07 MKV GLI, 07 F150
    Vancouver, WA
    So I messed with the coding, found out my "bose" wasn't even on, turned it on and it made it sound like crap...lol
    So I promptly turned it back off..sounds much better. What gives?
    I believe my eq settings are: 87578767
    --Mike--
    01 Casa S4
    07 MKV GLI
  13. #93
    Sep 14 2006
    03 TL-S
    What do you mean your bose wasn't on?
  14. #94
    Nov 10 2004
    Vancouver, WA
    Well my coding was 00003. It didn't say "bose" when I turned it on. I changed it to 00017, and it now says "bose" when you turn it on, but it sounds like crap. And it didn't change my EQ settings, cus I checked that. It sounded like it cut all the bass out. But once I changed the coding back to 00003, it back to sounding pretty good for stock.
    --Mike--
    01 Casa S4
    07 MKV GLI
  15. #95
    Senior Member Four Rings *Blue-Angel*'s Avatar
    Sep 11 2007
    2000 S4 TT RaceCar & 2007 IS350 ;2007 Mazdaspeed6
    Tampa,FL
    my radio is locked. i tried what the OP said with the button pressing and that is not working...any helpfull hints on another way to get this damn radio unlocked
  16. #96
    May 26 2009
    '03 Passat 4motion
    Bell Canyon, CA
    Try removing the radio and unplugging it and plugging it back it... We in the business call it a "German Reset" or when talking to a customer a "capacitive discharge" After that you should be able to enter your code. You might also have to leave the radio on for 1 hour if you put the wrong code in too many times. Its a built in extra security measure.
  17. #97
    Sep 11 2007
    Tampa,FL
    Quote Originally Posted by MattyJ View Post
    yeah could be that the dealer before me input a bad code several times. ill try leaving the radio on for an hr if that doesnt work ill either pull the battery terminals to reset or pull the power from the actual radio itself. thanks for you input
  18. #98
    Sep 14 2006
    03 TL-S
    You do have the actual correct code, though, correct?
  19. #99
    Sep 11 2007
    Tampa,FL
    yeah i had a dealership look it up for me. i just havent gotten the unit to allow me to input the code yet.
  20. #100
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Bumping this thread for all the new stereos going out lately. Awesome write up and this should be really handy for the next few weeks.
  21. #101
    Senior Member Three Rings happy2B5's Avatar
    Jul 18 2009
    S4 avant, Imola sedan, '90 GLI
    CA
    Quote Originally Posted by Chris@ECSTuning View Post
    or next month...I for one am glad to have read this. relatively new owner and had no idea. mine was flatlined at factory settings. pretty noticeable difference.
  22. #102
    Senior Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    What if my both speakers doesn't work anymore. Left rear door speaker and trunk deck left speaker.
    That looks bad right? Any way to giagnose that?
  23. #103
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Reich View Post
    You left channel could have gone out. I'd first pull the radio and check the wiring for pinching or breaking. If that checks out, L/R issues sound like a head unit issue to me.
