Results 1 to 8 of 8
    Mar 14 2007
    MN
    suspension rattle
    When I hit bumps my suspension makes a little rattle noise. I do have stasis street sports on my car so is it just normal noise or do I need to get something checked out? Thanks!
    Established Member Two Rings LUKAS(awd4eva)'s Avatar
    Jan 24 2006
    2000 AUDI s4 6 speed
    Frankfort ILL
    Re: suspension rattle
    i just noticed the same thing on my car, but i have stock suspension,
    Giac chip / Giac race program/ 710n's / rs4 clutch / darintake mod /Neuspeed Titanium 3" Exhaust / 5% tints / valentine one / piggie pipes / tt shift knob / apr snub mount / raderwerks 18'' MTEN80BK wheels / cc mod/
    auto meter boost gauge/ k&n air filter....
    Veteran Member Four Rings W1CK3D's Avatar
    Sep 19 2006
    Just my S
    North 'burbs (Chicago)
    Items for Sale
    Where in the suspension is the noise coming from? If you can narrow it down to "only when I turn left going over a bump" or something like that we can give you a better idea. As is it could be one of 20 things
    Current: 2002 Nogaro B5S4
    Gone: 2006 Dolphin Grey B7S4
    Gone: 2000 Nogaro B5S4
    Senior Member Two Rings quickdub's Avatar
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    jack it up and shake'er down... that's the only way you're going to find the culprit. Typically its a ball joint or control arm bushing going bad. Could be a tie rod end as well... How many miles on the car?
    Mar 14 2007
    MN
    It is when I go over a bump and sounds to be comming from the front. The car has 70,000 on it.
    Sep 19 2006
    Just my S
    Items for Sale
    Do you know if its had anything replaced before? I'd guess control arm bushing, like quickdub said jack it up and see if anything is loose or moves on either of the front wheels.
    Registered Member Two Rings eurospeed94's Avatar
    Mar 19 2007
    the b5, 900se cnv, cbr1000
    Horseheads NY
    Quote Originally Posted by LUKAS(awd4eva) View Post
    Stock a4/s4 springs are known to crack and break the base coil. I had it happen to me...not sure if its your problem but definately sounds just like the noise i was hearing. if you can define where its coming from jack it up on that corner and take a look...you'll see the base coil either missing or wrapped tight around your shock. Don't blame yourself...way too common on the B5 chassis.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    I've finally narrowed down my weird suspension/drive train noises.... it's coming from the front right shock. When I push down on the quarter panel, the shock squeaks and moans as it moves up and down. Also, when I drive and I deccelerate, I can hear the noise, it sounds like popcorn popping, or a piece of lose metal grinding something. I've jacked it up and had the wheel off, everything is tight down there, so im convinced that sound is still the shock. Is this the sign of a failing shock ? Everything on the suspension is stock, 78k miles.
    My car is fast
