Results 1 to 2 of 2
    New Member One Ring
    Mar 24 2007
    savannah, ga
    Door Lock issues
    So my 1990 200 TQ is having some door lock assembly issues. Currently, the car can only be unlocked from the passenger side door lock. The drivers side door lock doesn't open with the key.
    Recently on top of that, the passenger side door handle won't close properly, and the door will get jammed when closing, and not close fully. The metal hinge will hit the car door panel, and not close while the handle stays up.
    The car only unlocking from the passenger side is the biggest let down, but does anyone have solutions for these? Thanks.
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    Re: Door Lock issues
    You've got a great car! I'm a big fan of the I-5 20v turboes.
    Door locks are a very common problem for audis, especially older ones. The most common problem concerns vacuum leaks. Its usually a simple replacement tube, but I don't recall where its located. try asking here: www.motorgeek.com
    Otherwise talk to a trusted Audi VW mechanic.
    btw, got your pm. you can apply online at www.audiclubna.org
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
