Results 1 to 21 of 21
    Established Member Two Rings vLeuv's Avatar
    May 07 2005
    Blacksburg/Virginia Beach, VA
    Can't get Windshield grime/film off - Help?
    Here's the story
    So last summer when I was home from college It was like 105+ degrees one day (Virginia Beach VA) and my mom had the guy that usually washes her car do mine. When I went outside he was washing the two cars at the same time (shitty). I noticed that there were soap suds all over my windshield and the windshield itself was kind of steaming. I had applied Rain-X a couple of weeks before hand and saw that the suds were beading up in the normal Rain-X fashion.
    So since that day, anytime there is any condensation, moisture, rain, or even in certain lighting angles and at night (street lights absolutely suck), I can see watermarks and it almost covers my whole windshield (kind of look like stretch marks). Its gritty to the touch on the outside and feels like sandpaper. I really don't know what it is.
    I've tried every Glass cleaning product I can get my hands on. Invisible Glass, 20/20, etc. I even went to a local glass supplier and got one of their employes to look at it. He told me to buy this abrasive glass cleaner. I did and used it, again NO Luck. Vinegar and old newspapers, NO Luck.
    Anyone ever heard of this or have any suggestions?? (other than a new windshield)
    --Thanks in advance --
    Registered Member Two Rings KnivesOut's Avatar
    Feb 26 2007
    03 A4 1.8TQ, 95 4Runner 4WD
    Houston
    Re: Can't get Windshield grime/film off - Help?
    Have you tried a clay bar on it? Might be worth a shot.
    Nov 14 2006
    Tacoma, too many motorcycles, no Audis
    Renton, WA
    You could also try scraping it with a razor blade. Spray it with Windex and scrape away.
    -Darrick
    No more Audis, but can't leave this place alone.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Razor that shiiieat
    Established Member Two Rings damionphillips's Avatar
    Feb 07 2007
    03 A4 3.0/87 e30 325is/00 RL
    Dallas
    try WD-40 as well...removes bugs really well, so that and an ice scraper might clean the film.
    Currently swapping out the A/C controls for faster ones...
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I have the same problem on my windshield and have no luck trying to rid myself of the problem.
    So a razor blade... seriously?
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    no need for razor blade - i did that once and scratched it
    get a thick like compound - clay bar would work but don't use water based compound as it'll just react with the rain-x
    then use ur ice scraper and scrape it - then wash it off - should go away
    Jun 11 2005
    Vancouver, BC
    I see the 'scratches' left behind from the ice scraper I used this winter.
    So claybar and some other lubricant compound might work eh?
    Established Member Two Rings cdyer77's Avatar
    Jan 14 2007
    Phoenixville, PA
    mineral spirits then reapply the rain x
    Chris
    2010 TT-S - APR Stage 2+
    2004 A4 Avant - Sold
    Nov 14 2006
    Renton, WA
    Quote Originally Posted by 47Ronin View Post
    no need for razor blade - i did that once and scratched it.
    Then you did it wrong.
    -Darrick
    May 07 2005
    Not using Rain-X anymore. Ordering a set of the Bosch Aero Wipers. But I want to try and get this off before I put the new wipers on.
    So consensus is Razor blade, Clay Bar, and maybe mineral spirits?
    Sounds good I'll try them tomorrow and let you guys know what happened. Keep the recommendations coming.
    thanks
    Registered Member Two Rings King_Audi's Avatar
    Mar 23 2006
    '08 Mazdaspeed 3, '02 Audi A4
    Glass stove top cleaner!!!...
    I have a solar panel that had salt water spots all over it. Windex, Goo-Gone, none of that stuff worked. But the oven top cleaner made it look brand new again.
    2008 Mazdaspeed 3 GT!
    Cosmic Blue Mica with the works... (except Navi, but I don't get lost much) :P
    2002 Audi A4 1.8T/Q
    black on black, sport pkg.
    APR Stage 1, compressor inlet hose, snub mount, Bailey DV, ECS Drilled/Slotted rotors, RS4 rear sway, One Badass Momo Shift Knob. :D
    Senior Member Three Rings ravenmadx's Avatar
    Jan 26 2007
    07' White A4 Sline 2.0T
    Germany
    Use a clay bar its safe, it is an inherently mild rubbing compound. Clay bar is alot safer than a razor blade. The Easy-off is a good idea, because it works on my Glass stove, but watch out for your paint and plastic with the over spray.
    Jan 16 2007
    Wetzlar
    only Bon-Ami
    May 07 2005
    damn. glass stove top cleaner, never thought of that. I'll go try it right now.
    thanks
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Quote Originally Posted by King_Audi View Post
    That's not a bad idea! Also try acetone or Goo gone. If you can't get it off with that shit, get a new windshield!
    Veteran Member Four Rings Doss's Avatar
    Sep 18 2006
    Tools
    Top of the Mountain
    Ok, Windex with a razor usually works (or any other sort of lubricant).
    I've done it on several vehicles and had it come out all right. But, you are hamfisted, forget this idea b/c you'll probably screw it up.
    Your next choice is to sand it with 1000, 1200, 1500, 2000+, then buff it. If that doesn't work (it will), your windshield wasn't going to get clean period.
    Doss --------- ESP & SM SCCA racer
    '95 Mustang Cobra hardtop 'vert ---- Modified 6.4 F250 ---- '13 Audi allroad
    Originally posted by remembertofocus
    its just that you seem to constantly come off as an ass... maybe try putting it in your sig
    Me
    "Without failure, there is no progress. " "Taking the first step wrong may be the best thing you ever did."
    May 07 2005
    So it is possible for a Windshield to get so dirty that it can't be cleaned and only replaced? I would have thought that you could always use some chemical or something.
    I'm going to try the Clay bar and Razor blade+windex this weekend
    Glass Cook-top cleaner didn't work. It kind of took the grittiness down so it feels much smoother but still can't get it off.
    Jan 16 2007
    Wetzlar
    once again get Bon-Ami, it really works.
    Aug 26 2005
    Another product that has worked for me, is Castrol Super Clean to lubricate the clay bar. If you try it keep it off the paint!
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Items for Sale
    Stop using the Rain-X.
    Use a razor blade + any cleaning agent.
