Results 1 to 40 of 48
    NC
    Brake Light flashing...
    The last couple times Ive started up my car and driven away, my brake light just starts flashing. Someone tell me why this keeps happening. Thanks.
    Veteran Member Four Rings LAZY TURBO's Avatar
    Jun 01 2005
    La Crescenta, CA
    Re: Brake Light flashing...
    i think you need new brakes
    ~Sevan
    USP CLUB MEMBER #1 <~CLICK IT
    NC
    Is this it? Anyone else had this happen?
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    the brake as in the hand brake light?
    Registered Member Two Rings bimmerkilla1.8t's Avatar
    Sep 17 2006
    2003 audi a4 1.8t - 1969 bmw 2002
    burbank
    ive had it happen. your brake fluid is low. either in the resoivor above the master cylinder or in the abs resoivor located behind the master cylinder. in the abs resoivor, you want the fluid level to be above the bottom of the screen to the point that it is about 1/4" above the bottom of the screen filter thing.
    NC
    Yeah its the e-brake light...It will flash for like the first minute I start my car and drive off.
    Sep 17 2006
    burbank
    yea its going to be the e-brake light that flashes. did you see that i answered your question? youre low on brake fluid probably in your abs resoivor!!!
    Established Member Two Rings mhemperly's Avatar
    Oct 19 2006
    Glendale
    FLUID, definatley, if that doesnt fix the problem, I know after I had my car lowered the ass holes forgot to tighten my driver side rear a-arm bolts and my wheel would move front to back, and it caused my brake light to flash during hard turns... but most likely it's your fluid
    Dec 20 2005
    2003 audi a4 quattro, 2000 ford focus turbo
    San Antonio
    mine has also been doing this lately, flashing intermittently and beeping all the time. its annoying as hell. ill have to check the level...
    2003 A4 quattro, black/grey, 19in. ADR m-classic, tein c/o, ghl exhaust, carbonio V2, jl mids, subs and amps
    2000 Ford Focus turbo, 460hp crazy egg
    Sep 17 2006
    burbank
    lol, looks like ppl need to be doing better mainainence on thier cars. mine did it after i bled my brakes. the level in the master cyl was full cuz i had been adding as i went but i didnt even know about the abs res. i noticed the flashing light on the test drive around the block and it took only about 5 mins to solve the prob. if the light is flashing you should atleast try to figure out what is wrong right away especially if the light thats flashing says "BRAKE" and beeps. brakes are pretty important...
    Jan 24 2006
    orlando
    this just happened to me when i got my car back from getting ss lines put on. the reservoir above the MC is full, but where is the abs reservoir that's located behind the master cylinder?
    i also read you need to check under the little yellow cap on the brake fluid reservoir, but it's full in my case. do you think the brake light flashing could be caused by an improper bleeding procedure? the brake pedal has farther travel than it used to have.
    Jul 29 2009
    Colorado Springs
    Lightbulb Re: Brake Light flashing...
    Quote Originally Posted by bimmerkilla1.8t View Post
    Can somebody please give a more precise location for the ABS reservoir on an 2003 Audi A4 3.0 Quattro please. What would be the correct procedure for bleeding the entire system through with new fluid. I just changed the rear pads whilst keeping the master reservoir topped up and now have the annoying beeping and flashing BRAKE light on the display. Any assistance will be greatly appreciated.
    Senior Member Three Rings ridefastdietryi's Avatar
    Jun 08 2009
    04 A4 1.8t
    camarillo,ca
    LOL wtf my car does it now! random but even while im driving it will do it!!
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    http://www.audizine.com/forum/search...archid=1590568
    lots of threads on it.. you are likely low on fluid. my car also does it when i corner very hard
    Quote Originally Posted by brynreynolds View Post
    upper right side of engine bay.
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Veteran Member Three Rings aalipio's Avatar
    Sep 03 2008
    05 S4 V8 02 A4 1.8T
    N las vegas
    whats the *yellow* BRAKE LIGHT light on the lcd display? anyone have an idea? it came on when i started the car.
    Thanks
    Jul 29 2009
    Colorado Springs
    Problem solved with ridiculously stupid ease and thank you to those that replied...
    I removed the brake reservoir cap and breather plug, removed the brake fluid filter insert (and have permanently now left this out, as only an idiot would remove the cap without cleaning it) and then played with the brake fluid 'float' which is presumably attached to a brake fluid level sensor. The float has a degree of play from side to side aswell as up and down and had stuck to the side of the channel it moves up and down in, therefore misrepresenting the fluid level.
    I would suggest this fault is also the cause of people getting the brake warning light come on when cornering with a degree of passion!
    Apr 01 2010
    MASS
    Arrow
    My 1999 Audi A6 (quattro) is suffering from a flashing BRAKE light. I checked the main reservoir at the center of the engine bay, closest to the windshield. It was full. Is there another reservoir? Where is it located? Does it get filled with the same fluid?
    Thanks so much!
    Jul 29 2009
    Colorado Springs
    Quote Originally Posted by koskom View Post
    Thanks so much!
    There is only one reservoir, but on most cars you need to remove the rubber seal and plastic cover along the entire back portion of your engine to be able to access the breather plug on the top front left of the reservoir (it is a yellow, flat plug opened using a flat blade screwdriver). I found that removing both the cap and the breather plug, then checking the correct operation of the 'float' resolved my problem; I hope your situation is similarly very easily resolved.
    Apr 01 2010
    MASS
    Wow, thanks for the quick response! I also noticed some new smells around the car, and I hoped it would be resolved if I could find a place to pour some more fluid... Sounds like maybe I'll need to have a professional take a look
    Senior Member Two Rings jdogg's Avatar
    May 19 2009
    Thanks so much!
    Take the cap off the reservoir, and rub your finger around the screen. It sometimes just sits on top of screen, instead of seeping through. Giving the reservoir a full look. When actually its just pooled on the screen. Mine was lighting up and doing this. Just finger the screen.
    Mar 01 2008
    2008 A4 2.0T S-Line
    Hamburg, NY
    You have to love when someone actually takes the time to not help on a thread and goes out of their way to say "why didnt you think of this on your own".
    Thanks to all that posted with real solutions, I had changed my brake fluid 4 months ago and started to get the same problem, somehow I have lost a little level and needed to top it back off. Now I'm checking all my hoses and connections to make sure there are no leaks but this was a great starting point!!!
    Veteran Member Three Rings tatarin's Avatar
    Feb 11 2008
    05 B6 S4 Nogaro 6spd
    deerfield IL
    Had the same issue... i took the little screen out and fingered the level. light turned off!!!!!
    Veteran Member Three Rings zamflip's Avatar
    Sep 21 2010
    Bayliner 175, 2014 JGC wk2, and wifey s40
    Smithfield, ri
    Items for Sale
    damn old thread but i gotta ask you guys for the most idiot Q-- how to remove the little screen?? i just dont want to break it :-/
    Dec 14 2011
    Mirabel, Quebec, Canada
    Quote Originally Posted by zamflip View Post
    Stupidness here too. Been struggling with that as well ...
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    Gonna try this tomorrow lolz. I keeping getting a brake light symbol in my LCD randomly. It comes and goes as it wishes with no warning. Hopefully this is the case.
    Apr 07 2011
    Had this issue with the B6 I just picked up so I added some DOT 4 and all better now.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    HD/SoCal
    Last two days I've been having the same damn thing. Still have the search results up on my phone with the same thread lol.
    HIS: '05 A4 Atlas Avant 2.7t
    HERS: '08 A3 2.0TFSI DSG SLine
    THEIRS: '03 A4 Polar Sedan 0.0
    IG: @murky_rivers
    Knallhart Motorsports
    Apr 07 2011
    Check the level. I cleaned up the reservoir and could see on the side that it looked low. I added the fluid, started it and brake light was gone.
    Aug 26 2005
    If the fluid level is low in the brake MC reservoir, then the reason for the lost fluid needs to be determined. While simply refilling the reservoir is required, the cause of the low level needs to be evaluated. However, as the brake pads wear, the caliper pistons move outward, and that requires make up fluid from the reservoir. Regardless, brake pad wear should not result in the level of the brake fluid in the reservoir to drop below the minimum level line mark on the reservoir. With the reservoir topped up to the max level line with new brake pads, the level in the reservoir should remain above the minimum level line with the pads worn to the replacement thickness.
    Vorsprung durch Technik
    Nov 21 2011
    UK
    i get the red light flashing accompanied by three beeps - its a bit disconcerting but everything seems to be in order. Someone advised that if the battery was not fully charged this would happen - the car was parked up for a week and when i started it this week it was continuously beeping with the big red brake symbol flashing away. Seemed to improve after the car warmed up and a bit of a drive. No error shows up on vcds though. I put it on charge today for a few hours and only got the beeps once, so will charge ot for longer tomorrow and see what happens. otherwise open to suggestions.
    Veteran Member Four Rings Knives1010's Avatar
    Mar 17 2014
    2006 Dodge Charger SE
    Olympia, Washington
    Has it been extremely cold there? Mine started doing this after temperatures got below 20(F) degrees. The plastic around my drivers side e-brake cable was cracked and allowed water to get in, and the water froze around the cable leaving it clamped
    Oscar "The Grouch": Is now dead thanks to a drunk driver RIP
    Nov 21 2011
    UK
    just to update this - i also removed the reservoir cap, wiggled the strainer a bit and it all seems fine now :) Nice when the solution is that easy!
    Jan 20 2015
    West Haven
    ok guys I have an Audi a4 b5 quattro oh yeah it is a 2001 car has been sitting with the e brake on for awhile (std shift) My son gave me the car and I have been going thru it but now I went and released the e brake and I have a red brake light flashing at me the reservoir is full but it still is flashing and ideas?
    Aug 27 2013
    Philly
    Quote Originally Posted by excalibur451 View Post
    first, your in the b6 forum.
    That aside, stick your finger down in the reservoir and switch around and move the float around. That should help you out.
    2003 3.0 6 Speed - Quattro. 151k.
    Dec 18 2011
    Colorado Springs
    Time for a necro bump..
    This issue has low plagued my B6..
    Drained most of the fluid out of the MC using a vacuum bleeder, played with the float to see if it was stuck, refilled with fluid..
    Issue still persists. It's NOT the handbrake switch, I verified that by removing and actuating by hand, that says "handbrake applied" if its not working correctly.
    I have brake lights so its not the brake switch, and my MC is full of fresh DOT 4 fluid..
    Is the actual sensor on the bottom side actually bad? Can I loop the plug with a wire to make it go away and or to test the sensor?
    '03 CB A4 1.8T @ 202k! - ECS Snub Nose - ECS RA4 SMFW w/ S4 disc - TFSI Coils w/ BKR7EIX & ECS Plate - AFE Filter in Modded Airbox - Test Pipe - B5 S4 Front Brakes - B7 A4 Rear Brakes - Goodridge SS Lines - Bosch 550cc - Motoza 91/E85 MTC Tune - FMIC - Forge DV - Forge TIP - 034 RSB w/ 034 Links. Built Motor and BT to come soon 12/2016
    Aug 01 2015
    illinois
    My brake light kept blinking and beeping and I added a little dot 4 fluid, and it stopped instantly!
    Oct 30 2006
    05 Mini Cooper S
    Quote Originally Posted by B6A4Dave View Post
    Make sure the meshing inside the reservoir is not sucked down. If it is it will throw the light even if it is full of fluid. Take a 90 degree pick and pull it up gently.
    -MilitantGrunt- Certified Audi Dealership Technician
    -F30 Estroil Blau 335 Xdrive M Sport 6spd.
    -Brilliant Red B6 A4 Ultrasport 1.8t Avant 621whp - RIP
    -Silver B6 A4 Ultrasport Sedan - SOLD
    https://www.facebook.com/auditech/
    Mar 07 2010
    toronto
    sorry to highjack but I have a flashing brake light come on however the issue I have been having is related to my clutch pedal. Sometimes I have normal pressure and other times I have none. I have to turn the car off to get the pressure back. Any idea if this would just be related to low reservoir fluid?
    Any input would be appreciated.
    Dec 28 2006
    '03 A4, '13 A5, '18 MB-GLA
    Western Maryland
    Items for Sale
    I assume you have checked the brake fluid level?
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint / Neuspeed Power Module / black window trim / RS grille.
    Mar 07 2010
    toronto
    Yes, that was the first thing I checked. It was at a normal level.
