Page 1 of 19 12311 ... LastLast
Results 1 to 40 of 760
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 qT
    MOntreal
    engine build with pictures
    BetaAlphaTau member #19
    INAEngineering.Com - Most powerful 4 cyl Audi
    tkrace.com Fastest and most powerful 20v 4 cyl VW 715whp 9.14@164mph
    rawtekinc.com custom exhaust systems
    1.Fidanza flywheel machined for sprung hub 100$
    2.1.8t head amb ported to large port spec with supertech valves $$$$
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Re: engine build with pictures
    I'll post more pics as these advances
    Veteran Member Four Rings LAZY TURBO's Avatar
    Jun 01 2005
    La Crescenta, CA
    pics dont work...
    ~Sevan
    USP CLUB MEMBER #1 <~CLICK IT
    Nov 24 2004
    2004 A4 qT
    MOntreal
    i just tried them now and they do scroll down in that window
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    2010 Audi S5, 2010 Audi Q5
    Warsaw, Poland
    Not worky
    2010 Audi S5 - 3G MMI, Seidennappa, B&O, Audi Drive Select and more
    2010 Audi Q5 2.0TDI
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
    Nov 24 2004
    2004 A4 qT
    MOntreal
    ok somebody tell me how to post them here the pics
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    Cars being worked on
    Fort Collins, CO
    Go to gallery, upload pics, browse, then click on your pic, then process. This will load them onto the audizine server. Might help if the server you are using doesn't want to display them here. Make sure they are jpeg so they are small enough.
    Go to see we are both there man. My fingers are crossed for both of us when we first turn it over. I could fire mine up right now, but apr sent me the wrong DP. Oh well it still ain't going anywhere with how these damn CO roads are right now anyway...
    Good luck
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Lost:A4 USP+ Found:A4 S-Line+
    long island, ny
    - joshua
    Sold to Dgro1! -> 02 A4 1.8t TiP Black on Black/35% Llumar Tint/USP Front/USP Rear/USP Wheels/USP Door Flares/OEM USP LiP Spoiler/Blacked Out Ecodes w/ 6000k Osram HiDs/Stealth Auto Bulbs Front and Back/Aero Wipers/RS4 Sway Bar/H+R Sport Springs/Bilstein Sport Shocks
    http://img171.imageshack.us/img171/1050/img3404ys8.jpg
    Veteran Member Four Rings gohan's Avatar
    sick! but what am I looking at?
    2011 E350 4matic
    2009 Honda CRV
    Former
    02 E46 BMW M3 6speed
    03 B6 Audi A4 Quattro 5speed
    http://img.photobucket.com/albums/v1...4/groupsex.jpg
    I MISS MY B6!!
    Feb 12 2004
    Fort Collins, CO
    first pic, the alternator is right in the bottom middle to the left of the orange oil dip stick tube, the intake runners going into the head are right next to it. second pic is looking at the cams, cam chain, top of the head with the valve cover gasket on, etc... 3rd pic is looking at one of the exhaust openings going into the exhaust valve at the head.
    Quote Originally Posted by CO AVANT View Post
    first pic, the alternator is right in the bottom middle to the left of the orange oil dip stick tube, the intake runners going into the head are right next to it. second pic is looking at the cams on the top of the head with the valve cover gasket on. 3rd pic is looking at one of the exhaust openings going into the exhaust valve at the head.
    that is really interesting.
    2011 E350 4matic
    2009 Honda CRV
    Former
    I MISS MY B6!!
    Nov 24 2004
    2004 A4 qT
    MOntreal
    yeah man we got the first real snow storm here too...nyways the car is out of comission until spring I still have to shit some pennyes to get this thing done...Tonight I am leaving for detroit witht the semi it's gonna be some fun
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Quote Originally Posted by gohan View Post
    co pretty much expleined it it looks messy but it's not that bad
    Feb 13 2006
    B6 3.0 Quattro (RIP), E55 AMG
    what engine is that?
    Black B6 A4 3.0 QMT6 (RIP)
    Black C5 S6 Avant
    Black W211 E55 AMG
    Feb 12 2004
    Fort Collins, CO
    1.8T
    20V, I forgot but did you end up using a different head? If so what code is it?
    Did you make sure all your timing marks lined up perfect? Since those cams don't have any timing marks and they just give actual timing figures you need to make sure those were installed perfect, but I'm sure you already know that ;)
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Feb 12 2004
    Fort Collins, CO
    I also see you used an external oil cooler, I presume. What brand and dimensions did you go with? Was I looking at the stock one right when I saw that both oil and coolant run through the same housing? I also replied above you at the same time you posted the first link for pics...
    Nov 24 2004
    2004 A4 qT
    MOntreal
    1.8T
    yes they are punched it's not exact..the guy that put the head together told me he used the punches in the cams and then he counted the links on the chain...U have to use a special tool to get the chain with the tensioner in...The marks between the 2 cams right now but there is no oil in the tensioner so it's normal to be a bit off I am calling autotech now i want to get this
    http://www.autotech.com/prod_engine_camgears.htm
    Nov 24 2004
    2004 A4 qT
    MOntreal
    yes I got the mocal adapter I bought some aeroqip fittings and line the core I got it off ebay a while ago about 100$ I guess it adds up about the same if you buy a kit may be just a bit less...I don't have the camera here right now but I'll have more pictures of the whole thing soon
    Feb 12 2004
    Fort Collins, CO
    Damn, I wanted a lightweight cam gear too. I also need to say enough is enough for now, lol. Those look nice though.
    Nov 24 2004
    2004 A4 qT
    MOntreal
    it's the original small port head but it has been ported, inconel exaust valves stainless intake ferrea all over and revolver cams....if you look at the ports u won't see much the real job is where the valves are, there are a lot of imperfections on that area in the casting...I wasn't looking to make the ports as big as possible I wanted equal flow between each cylinder and match port
    Nov 24 2004
    2004 A4 qT
    MOntreal
    I know is enough for me too but for a 100$ I rather do it now then take the whole thing apart again...It's so nice to work on it when that rad support is out of the way
    Feb 12 2004
    Fort Collins, CO
    yeah I ported my stock one too. More the intake than the exhaust side right at the openings, not much but definitely cleaner and better flowing. But yeah did more work inside by the valves as well. Did you have to overbore +1mm for the ferrea intake valves?
    Nov 24 2004
    2004 A4 qT
    MOntreal
    no I have supertech valves they ome in 2 sizes the over bore is for na
    Nov 24 2004
    2004 A4 qT
    MOntreal
    once you have the timing set do not crank the motor turn it by hand a couple of times If the timing is off by any chance the force of the starter will mess the valves...when you are ready to start disconect injectors and ignition and crank until the oil light goes off, i do this after every oil change, it will push oil everywhere including the turbo
    Feb 12 2004
    Fort Collins, CO
    Thanks for the tip. I did already crank the motor by hand, everything lines up perfect...
    Nov 24 2004
    2004 A4 qT
    MOntreal
    cool do you know where is the mark for the bottom I can't see anything on the sprocket
    Feb 12 2004
    Fort Collins, CO
    It's usually not marked with paint or anything similar. Look for a notch in it instead. Kind of like someone taking a little knife scratch/cut to it...
    Nov 24 2004
    2004 A4 qT
    MOntreal
    I know I found the nothes it's hard to see on the cover for the crank I have to time it with the oem dampener and then put the neuspeed one
    Nov 24 2004
    2004 A4 qT
    MOntreal
    actually the cooler you see in the picture is for the power steering...I removed the oem one and went with a different one...I have an oil cooler for the engine but is not installed yet
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    So, you built up a 1.8 with solid internals? Didn't stroke it to go 2.0?
    Sounds like it'll be a solid motor. I presume you'll end up with a big turbo?
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Nov 24 2004
    2004 A4 qT
    MOntreal
    exactly probably a gt30 or a gt 35
    Nov 24 2004
    2004 A4 qT
    MOntreal
    i did more than building a solid motor I optimised everything for high and swift revs I kept it 1.8 t because I wanted mahle pistons and because the 1.8 likes the high revs more than a 2.0...everything is lighten in the block and balanced for 10000rpms...the valvetrain is also optimised for about 9000rpms....beside block and head there is nothing oem in the engine..this was done to compensate for the lag of a bigger turbo
    Feb 12 2004
    Fort Collins, CO
    What compression ratio are you going to run? I got my JE pistons cut at 9:0:1.
    For some reason I thought you were going 2.0 stroker as well. A 1.8 will rev quicker, but the 2.0 bore/stroke will spool quicker. I guess both have their advantages and disadvantages... What exactly did you lighten in the block?
    Nov 24 2004
    2004 A4 qT
    MOntreal
    9.5:1 the crank is eurospec lightweigth knife edged forged crank...mahle pistons I kept the 1.8t because I wanted the quality of the mahle....I heard je are noisy and sometimes the knocks trick the knock sensors..I also have carrillo rods wich were already made in 144mm so i wanted to use those...Going 2 liter would mean diff pistons and rods...The rods I had already and the pistons I got from 034...it was 2 much of a hassle for 200cc Now a 2.2 would be interesting but I had not time and no money to play with that
    Nov 24 2004
    2004 A4 qT
    MOntreal
    the strength of 1 carrilo rod is rated at 750hp...So I made sure that it won't fly through the block this time
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Nov 24 2004
    2004 A4 qT
    MOntreal
    Nov 24 2004
    2004 A4 qT
    MOntreal
    this is my power steering cooler summit
