Audizine's Facebook Fan Page
+ Reply to Thread
Results 1 to 15 of 15
    Senior Member Three Rings mrponline's Avatar
    Sep 18 2006
    2008 Audi S5, 2007 VW Golf R32
    Sydney Australia
    Post ECU Removed and sent to APR (DIY Write Up)
    The 2007 VW R32 finally arrived last week so i finally have another car i can use whilst the Audis ECU is removed and shipped to APR.
    When the ECU comes back chipped with the K04 programs the K04 turbo and any other remaining parts will be installed onto the Audi.
    The ECU Write up can be found here http://www.audizine.com/forum/showthread.php?t=114129
    Last edited by mrponline; 01-15-2007 at 02:21 AM. Reason: Updated & moved write up to DIY section
    2008 Audi S5 6MT
    Phantom Black, 20" Forged DPE 3 Piece Wheels, Nitto Invo 285/25 Tyres, H&R Suspension
    2007 VW Golf R32 6MT
    2006 A4 2.0T Quattro 6MT Sline - SOLD
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: ECU Removed and sent to APR (DIY Write Up)
    Nice write-up! Would you mind if I copy this over to the DIY Forum as well?
    The Admin's Journal: http://www.audizine.com/forum/blog.php?2
    PREV: '99.5 A4 1.8T Avant | '03 GTI VR6 | '06 A4 2.0T Avant
    CURRENT: '95 Ur S6 Avant | '09 A4 2.0T sedan
    On a mobile device? Audizine Mobi is HERE!
    New Member Two Rings
    Mar 31 2005
    '06 A4 Avant 2.0FSI TQM S-line, '04 A4 1.8TQM USP
    Kona, Hawaii
    One more piece of advice (but won't be much help in Austrailia, sorry . . )
    Removing my wiper was very difficult, and I had the same problem with my B6. I found a tool at NAPA that works perfectly:
    "Tie Rod End & Putman Arm Puller" made by Performance Tool, part #W80557.
    This is basically a wheel puller, but it fits perfectly over the wiper arm - put it on and just give it a few turns and it will break the wiper loose pretty easily.
    mpronline - Nice writeup, great pics, thanks.
    Sep 18 2006
    Sydney Australia
    Not at all if you want feel free to copy it over and take out the comments above the write up if you like.
    2008 Audi S5 6MT
    Sep 18 2006
    Sydney Australia
    Quote Originally Posted by A_loha_4 View Post
    I have previously taken off the wiper in order to lift the plastic to get to one of the Torex screws which fastens the ECU protective cover but didnt this time as i managed to get a small Torex screwdriver in there.
    The way i got my wiper off was by giving it a couple of good pulls and it eventually popped off.
    2008 Audi S5 6MT
    Sep 29 2006
    Auburn AL/Friedrichsdorf D
    The "spot welded" bolt actually is not spot welded, heating the bolt up with a paintstripper alows you to remove it the same way you removed the green one, thus elliminating the need to cut the bracket.
    Sep 18 2006
    Sydney Australia
    Thanks Ben I gave it a go as the screws where still intact on the bracket. It worked beautifully you should of chimed in a few weeks back when I was looking for info on how to remove the ECU.
    2008 Audi S5 6MT
    Sep 18 2006
    Sydney Australia
    Write up has been updated and now includes two bracket removal methods and all new info that was provided by both A_loha_4 and Ben@Oettinger.
    2008 Audi S5 6MT
    Sep 29 2006
    Quote Originally Posted by mrponline View Post
    Ooops...sorry..didnt see that thread.
    New Member Three Rings bz0n3's Avatar
    Dec 25 2006
    A4 B7 2.0TM6
    El Paso, TX
    Quote Originally Posted by Ben@Oettinger View Post
    I thought that we were actually supposed to bring the vehicle to apr, and removing the ECU to mail it was not an option!!!
    *bz0n3, inc.
    |-| 06 A4 2.0T Manual MoDaFu**** FWD |-|
    http://www.myspace.com/bz0n3
    http://www.facebook.com/bz0n3
    Mar 31 2005
    Kona, Hawaii
    The ideal method is to take your car to an APR dealer and have them upload the program via "direct port". Some of use live in ares where there are no ARP dealers (like here on the Big Island of Hawaii or mrponline in Austrailia). We have to send the ECUs in in the old-school way by sending in to APR headquarters.
    Sep 18 2006
    Sydney Australia
    We do have APR dealers here in Australia. But i purchased my K04 turbo kit directly from APR in the US during Xmas special. But in order to get the programs i wanted (as the local APR dealer woundnt load them) i had no choice but to pull the ECU out and send it in the old school way.
    2008 Audi S5 6MT
    New Member Three Rings parks853's Avatar
    Nov 20 2005
    tucson, AZ
    probably not that bad since you are driving the R32 around. Let us know how things go after you get that ECU back and install the rest of your goodies.
    2005.5 Quartz Grey 2.0TQ M6 CAR FOR SALE - http://www.audizine.com/forum/showthread.php?t=197624
    Stage 1 Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    And I've found that if you push down on the spring loaded joint it puts the wiper in a more parallel position with the spline and it pulls off very easy. one hand on the spring loaded joint pushing it down, the other hand to pull the wiper off.
    New Member One Ring
    Apr 25 2008
    Australia
    Excellent write up, just removed one of the ecu's in the rs4. However I drilled straight through the screw because using the dremel to cut a longtidunal slot and then try and screw the (green one out) is near impossible. The other loctite security screws on the B7 RS4 are not accessable at all from underneath, so again pls add this to your excellent, detailed write up that on the B7 RS4 you have to drill the loctite security screws VERY CAREFULLY and you may be able to remove the green ones. In the rs4 they are not green in colour, they may appear normal silver, or have a red splash on them
    See my post on rs246.com
    Cheers
+ Reply to Thread
    © 2001-2010 Audizine, Audizine.com, and Driverzines.com
