Results 1 to 40 of 74
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    Fast Audi sedan, Slow Subie wagon
    SL,UT
    Post B5 A4 New Member Guide/FAQ! Answers to the most commonly asked questions!
    I "stole" this outline from the B6'ers and editted it for the B5'ers. so hopefully it can be sticky'd for now until the "official" AZ sticky's are done. i also added a lot of what i like to think is good info
    So you got a B5 A4 I.E. 1996-2001.5(1996-1999 = pre facelift, 1999.5-2001.5 = facelift), NICE! However, everyone else has an A4 and lots of them are faster and nicer then yours so before you ask dumb questions, use the search button a lot. also read everything on here. I REPEAT, SEARCH! AND READ EVERYTHING HERE BEFORE POSTING A QUESTION.
    Lets start out with factory options. Sport suspension has red shocks. To see them, look behind your wheels with a flashlight. If you have the cold weather package, good for you. Now onto the important stuff. Tiptronic basically sucks, its not “both”. You have a clutch or you don’t, I hate when people try to say they have both. If you have stick, awesome. 5 speed is the superior! As for motors, if you have the 2.8 (30v or 12v) some people like it. Basically all you have is an intake, exhaust, short shifter, and chip(30v only). The chip is not going to do as much as a 1.8T chip but still helps. 30v's also have the PES supercharger (www.pes-tuning.com).. If you have the money go 4 it! PES states that you can bolt the supercharger to the 12v but you need s/w. I.E. standalone
    Im going to focus on the 1.8T here because most of us have that. Here are pretty much all your mods that you can do…a lot are universal so can be used for the 2.8 too
    1. Intake – Ok so many cars can gain power from intakes but we cant… The only one that people like is the Carbonio but is it worth the $300? It has been proven to show increases and some think it is but its all preference. there is also the Evoms one but the stock heatshield that comes with it sucks. if you want to hear your turbo spool and your DV or recirculated BOV go psssht! then get a cone type filter(Evoms or homeade) and get the "true heatshield" LINK. all in all the stock airbox is good for about 300hp
    2. Exhaust – Because our cars are turbo, freeing up room for the turbo helps bring out power, so an exhaust is important. There are many companies (Borla, Milltek, APR, and Neuspeed are the most popular off the shelf ones). Some like it louder, and some like it softer. Borla would be the loudest then neuspeed. miltek and APR are stealth type exhausts so they are very quiet.. Make sure you get a good diameter depending on how much power your going to be putting out.
    2.25"-ko3 power
    2.5" to 2.75"-ko4
    2.75" and up- BT
    3. Test Pipe/High Flow Cat – As I mentioned before, freeing up room for the turbo is essential. A test pipe (TP) replaces the catalytic converter (cat) and makes for a quicker spool, more power, MORE NOISE! and a CEL(check engine light). to get rid of the CEL you have to do the "anti-fouler mod"~search it in the forums. Its an awesome mod but many stay away because it may be illegal in your state and the fines could be huge. it can also smell. Check if your state runs emissions tests on inspection.. a better way is to get a highflowcat (HFC) Miltek makes one that is good but $$$.. best one to get is the Labree one.. only slightly more than a TP and will be legal in a lot more states. and the HP differences between the two wont be noticable.
    4. Chip – A chip is probably the best bang for your buck and the most favored by most 1.8T owners. It remaps the feul and boost to push more hp on your car. The main companies are GIAC and APR. there is also Dahlback and neuspeed . Many choose based on which dealer is closest~very important. GIAC is the only one with upgrades for K04.. Dahlback also does but you need their expensive KO4 too..
    5. Turbo Intake Pipe (TIP) – The OEM turbo intake pipe or hose can be faulty and collapse under added pressure. A new TIP is a popular mod to make sure the collapsing never happens. APR is the most stout but is only available for the K03 and K04. The Neuspeed is 2nd on the list. It is less stout but still very good and can work for the K03/K04 and the eliminator applications.
    6.Boost Gauge – A boost gauge monitors boost from the turbo and is VERY recommended to make sure everything is running smoothly. AWE makes a nice one, as well as ECS Tuning's pod and VDO guage combo.. VDO is a cheap and good guage and the lights match our interiors very nice
    7. MBC/EBC – A manual boost controller or electronic boost controller is used to limit the boost that is put out by the turbo… EBCs are better but cost more and there are some MBCs that are better than others -DO NOT HOOK UP ON OF THESE THINKING THAT YOU WILL CREATE MORE POWER- our ecu's do not work that way
    8. N75Valve – This controls the smoothness of the boost essentially. Many people throw in an N75J or N75H valve to increase performance (which it does) but it makes the boost come in very harshly and can possibly put your car into limp mode (when your ECU restricts boost because it knows something is wrong)
    9. Diverter Valve/bypass valves in general – A diverter valve is most popular and is required for all chip and turbo applications that run more boost. It holds the extra pressure better. Forge 007, Bailey, Hyperboost, and other DVs are good. an OEM 710N DV will hold chipped boost without a problem and is a cheaper soulution. The blow off valve (BOV) is asked about. some say don't do it and will flame you. but as long as you take the necessary steps it can work. you just need to run a recirculation kit to make it work, basically taking the "blown off" air and runnning it back into the intake tract like the DV does initiallly.
    10. Short Shifter – Some consider this an Interior mod some consider it an engine mod. Basically it shortens shifts so there is less time in between. Neuspeed and B&M are popular. DieselGeek is also an awesome one for less money too. Ebay is also a great cheap one that people have had good luck with.
    11. Snub Mount/D.T.S. – this is the front engine mount of our motors. the stock one is a squishy rubber that allows a lot of play in the drivelines. upgrading to a polyurethane unit cuts out a lot of the slack and rubberish feeling while driving. The APR, Greedspeed, Vastperformance, and 034 snub mounts gets rid of the shifter/drivetrain clunking when hard shifting occurs. Its cheap and an easy DIY for us, go for it! the DTS, or drive train stabalizer, is a unit that bolts directly to the undercarage of the B5 using existing hardware and mounts. it also bolts up to the transmission reducing yet even more driveline slack. it's an easy install. a word to the wise though, throw away the junk rubber mount that comes with it and get a polyurethane one More info here. the two places that sell them are AWE and ASP. both are the same only a slight difference in price. but ASP is the only one that has a DTS for a TIP transmission.
    12. Clutch/Flywheel – a great man once said "Stock clutch wasn't rated for stock power" . When going past a simple chipped setup, with the added hard driving a clutch may be needed. It allows for better launches and better grab between shifts. ECS tuning sells a decent clutch but Southbend clutches are the best. The OFE SS is the top dog while the HD is a step lower. Make sure you get a new OEM dual mass flywheel when you get the clutch. Everything should be around $1100 without install.. our cars have a heavy DualMass Flywheel, DMFW, that assists in balancing and honing the engine. it's dualmass is separated by rubber bushings so this is yet another source of the rubberish feel to our cars. there is no problem with the DMFW other than its ~24lbs. a lot of people keep it after a clutch upgrade for numerous reasons. depending on the shape of it you can easily resurface it with a heavyduty scotchbrite pad.. as for a Light Weight Flywheel, LWFW, there are many options, Unorthodox, Fidanza, AWE-tuning to name a few. they will help your car rev quicker but some say it's too much for a daily driver. hard to shift smooth and creates chatter at idle due to our internally balance enigines.
    13. Intercooler – An intercooler is an effective and sometimes essential (for K04 or bigger) way to cool down IATs (Intake air temps) from the turbo so more power can be made. The FMIC (front mount intercooler) is the most effective and is placed in the front bumper. Evolution Racewerks is the best-once released that is. Racetek and APR are also nice pieces.
    14. Exhaust Manifold – A turbo manifold will open up your exhaust ports, allowing for more flow for the turbo. ATP makes a crappy one that most people use. APR has an awesome one on their Stage 3 kits, and there are some other ones that I cant think of. It is not required with the Eliminator kits but recommended. Most just bite their lip and get the ATP. for BT setups most go ATP as it is the only one easily available for cheap.
    15. Intake Manifold – Our stock ones are sweet, don’t worry about it, the Dahlback one is garbage.
    16. Turbo – So now you have your FMIC, clutch, exhaust and your ready for the new turbo and software to go with it. NICE!
    Turbo Options
    This is meant to be a short guide to turbo upgrades. There is a ton of info around here and other forums. Please make sure you use the search for additional info on the type of upgrade you're looking at prior to making a hasty decision.
    Some highly recommended parts to get before upgrading your turbo are pretty much all the things that you have just read in this. so get those first as there are certain steps and and order to things.
    K04
    The ko4 that you want is the ko4-15. Basic bolt in upgrade. No special required parts unless going for the pc-16, J31, or Hammer files from GIAC. Do not pay more than $800 for a K04 alone. They can be found on any of the various Audi forums for less. GIAC makes a very good program for it. $1300 and an install later you can be rolling with 200whp. When looking you will need the K04-15. do not bother on doing a ko4 for your 2001 A4 if you are not going with the Hammer file. the 2001 model year has the ko3s(sport) so there for the GIAC-X chip with the ko3s will only be slightly less powered than the ko4 on basic GIAC programming. for knowing what you need for these setups contact GIAC directly. as it will be easier than me typing it all out. KineticMotorsport has them for a good price usually
    PC-16 - 1997-1999.5 model years~usually runs in the 20-25psi range
    j31 - 2000~usually runs in the 25-28psi range
    Hammer - 2001 and 2001.5~i think usually runs in the 20psi range
    GT2X Eliminator
    Bolt in upgrade. Slightly larger than the K04. Good for 220Awhp. Most people use the Mika tuning from ATP, others use modified K04 software. it is only oil cooled unlike the other eliminators
    GTRS Eliminator
    Bolt in upgrade. Much larger than the stock K03. Produces roughly 350chp. Mika tuning or Unitronic for the B5.
    GT2871R Eliminator
    Bolt in upgrade. $95 more than the GT28RS elim. good for 400chp. Mika or Unitronic for the B5.
    Note: For the eliminators, I highly recommend a braided oil return line. The stock oil return will work, but it's a pain to get in. Unitronics for software, but also Mika tuning offered by ATP can be a good software. but FWIW not off the shelf. it requires tweaks to get things running right. some have run tweaked ko4 software with success on this big of a turbo. ATP and Renn-Art are the best places to get the eliminator products. Renn-Art has a proven kit.
    APR Stage 3/Stage 3+ kits
    APR has a stage three kit with everything you need to get your BT up and running. they have their stg3 GT28r kit for 1997-2000. and their stg3+ GT28RS kit for 2001s. both are very respectable and worry free kits that a lot of people love. APR's website for more info
    Full GT28RS
    Requires ATP or custom exhaust manifold, custom downpipe, and custom intake. Approx 400chp, depending on the tunng and supporting parts. Needs custom tune, standalone, or dyno tune.
    Full GT2871R
    Requires ATP or custom exhaust manifold, custom downpipe, and custom intake. Approx 400-450chp, depending on the tunng and supporting parts. Needs custom tune, standalone, or dyno tune.
    T3/T4
    Requires ATP or aftermarket exhaust manifold depending on flange, custom downpipe, and custom intake. hp numbers vary as there are numerous different sizes, Trims, A/R's and such. Requires custom tune, standalone, or dyno tune. CTapp is also a good option for software.
    GT2871R elim vs GT2X elim vs Stock K03
    17. Water/Meth Injection - Ok so the new big thing on here is water/meth injection. Basically it allows for a water/meth mixture to be shot into the intake manifold to lower temps and allow for more timing (such as running a race file on pump gas). The DevilsOwn and SnowPerformance kits are great. It is AWESOME but the effects could be dangerous if correction factors get too high. Check out Timing 101 near the bottom if you have no idea what Im saying
    18. VAG-COM - This could be one of the most important things you get for your B5 as you start to mod. VAG-COM is a software made by Ross-Tech (www.ross-tech.com) that can Erase/Read CELs, Get rid of the seat belt chime, enable remote windows up/down, and most importantly, LOG! With VagCom you can log IATs, knock, CFs, RPMs, Engine Temp, blah blah... Here is the website to see more features B5 VAG-COM... Its about $220 from them for the full licensed verison or you can get an Ebay cable and get the lesser version for $20-100 for that cable
    19. Suspension - Suspension is just as important as power. Being able to control your car is essential and coilovers or shock/spring combos allow for this... There is much controversy over which ones are the best. Stasis products are great. Their tracksports and motorsports are well known. The Bilstein PSS9s are also highly recommended. H&R is good quality. Vogtland and KW make fine products also. for the more frugal individuals the Eibach Pro-Kit coils, Koni Coils, and Stasis Streetsports get the job done! As for shocks and springs, Bilstein/H&R is most popular. also Koni shocks and eibach and neuspeed springs work well too. just put them together in the right combo.
    20. Sway Bars - Neuspeed (29mm front, 19mm rear) are good. H-Sport's(35mm front, 22mm rear) are by far the best. either ones that you get, make sure you get the reinforcement bracket system. some that have run without them have cracked their subframe's.
    21. Brakes - The simplest upgrade is an A8 312x25 rotor with Porsche caliper brackets(with special brackets from ecstuning or bira.org). If you do it right, you might not even need to bleed them. in the future. This fits with almost all wheels, even 16's. ECS tuning has some awesome Brake systems that you need to check out. also stainless steel lines are a cheap way to improve the braking feel. they don't expand like the OEM lines thus making the braking more firm and responsive.
    21. ECU/Engine Codes - our car's generation is broken up into two different ECU's and three different Engines for the 1.8T.
    1.8T AEB = 1997-1999
    1.8T ATW = 2000
    1.8T AWM = 2001
    AEB is DBC(drive by cable) or a.k.a. nDBW(non drive by wire) meaning that there is an actual cable conected to the throttlebody. which is more easily tuned
    ATW and AWM is DBW(drive by wire) means that the ECU, the computer, controls the throttlebody. harder to custom tune and can have a mind of its own sometimes..
    AEB has the larger port head and 20 mm wrist pins.
    "ATW is the bastard engine w/ the AEB bottom end and the small port AWM head" 94jedi.
    The AWM has 19mm wrist pins, small port head and internal waterpump
    22. TimingBelt - our engines are interference engines meaning that if the timing belt breaks, waterpump fails, or tensioners fail then the pistons slam into the valves bending them. and costing you big money to fix. audi suggest that the timing belt and such be replaced in 120k intervals. but experience has shown that that is false. they should be replaced in 60-70k intervals to be safe. some have gone longer but it's not worth the risk. the change is a strait forward process it just takes time due to the entire front end has to be removed. ECS Tuning and Purems sells the best kits for a worry free switch.. it's best to do all belts, rollers, tensioners, and waterppump at once since you already have the front end off. and this is also the best time to do a Snub mount that i mentioned earlier. takes 2 minutes to install during the TB process.
    23. Headlights - there are two different sets of headlights for our cars. pre facelift's have two peice non projectors where as facelift's have one peice projector lights. 2000 and 2001 had HID's as a factory option. 4300k and you will know if you have them by looking at them while on. if not there is a ballast on the back of the headlight housing that has a lightningbolt on it. if you don't have HID's then no worries because they are a cheap and easy upgrade. provided you have projector housings. if you have 2 peicers then first upgrade to OEM projectors, Valeo Ecodes(the best), or even Depo Ecodes off of Ebay(but stay away from all other Ebay lights!). cqlight.ca is a popular place to get a good kit, link down below. also Ebay has some good kits provided you buy from a reputable seller.. OEM 4300k are supposed to have the most light output you can get. then there is the 6000-6500k which is the most pure white you can go. 8000-10000k are bluish and beyond that is purpleish. 3000k is a yellow and a poplular choice for foglights. All bulb numbers can be found here
    LINKS
    Performance Parts and Tuning:
    034 Motorsport
    Achtuning
    Advancedmotorsport
    APR
    ATPturbo
    AWE-Tuning.
    Brembo Brakes
    Dahlback Racing
    Dieselgeek
    ECS Tuning
    Evoms
    GIAC
    Hoppenmotorsport
    Kineticmotorsport
    LLtek
    Neuspeed
    Oettinger
    PES-Tuning
    Purems
    RENN-ART
    STaSIS
    Stratmosphere
    Stoptech Brakes
    Supremepowerparts
    Ultrarev
    OEM Parts:
    http://www.germanpartsonline.com/
    www.thepartsbin.com
    www.autohausaz.com
    www.4usedaudiparts.com
    www.dadsauto.com
    http://worldimpex.com/
    http://www.car-part.com/
    http://www.germanautodismantlers.com/
    http://www.clairparts.com/
    Misc:
    1.8T Troubleshooting Guide-LOOK HERE IF YOUR CAR IS ACING UP.
    B5 A4 External Differences
    http://www.ross-tech.com/
    VAG Tool Locator - Registry of individuals with Audi/VW VAG tools.
    Bentley Fault codes
    Decoding VAG fault codes
    logging blocks with VAG-COM
    cqlights.ca - great HID kits!
    www.hid-lights.com
    Acronyms-
    Can all be found here
    PEACE!
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Changes monthly...
    Sammamish, North Bend, WA
    Re: ULTIMATE n00b GUIDE!!! read before posting plz!
    No, thats perfect. Maybe put somethin in there about not asking questions until you have conducted a nice search first, due to bandwith, etc. etc.
    EUROPROJEKTZ
    Click Here for Daniel's Audi A3 Build
    Real Estate Management|Developer|Entrepreneur: www.dbverwers.com
    Looking for Affordable Housing in the Northwest? www.MyNewDwelling.com
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    nice job man.
    Mods should delete our posts, sticky this to the top, and lock it so it doesnt fill with nonsense
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Sep 17 2006
    SL,UT
    well the B6 one is still going unlocked so i see no reason why this one can't stay open. that way people can post up anything they think should be added. im no Guru IMO btw.
    it is improving every few minutes when i remember things to add.. im in the process of making things better on the link section
    Senior Member Three Rings hey4's Avatar
    Feb 10 2006
    1999.5 A4 1.8TQM
    Twin Cities
    you've done what I've been meaning to do and you did a great job. I think we should have the thread open as some questions will be asked in it and that way we can add stuff that seems too simple to us or something that hasn't been mentioned. Ie. BT= big turbo, most people don't know the acronym or what it stands for.
    Parting out 1.8T pics included, pm me if you need any parts or hve any of the suff I'm looking for!
    WTB: 00-02 black ashtray
    FS: Various ATW parts
    Veteran Member Four Rings E Fresh's Avatar
    Aug 24 2004
    has an Audi
    Socal, Irvine/Aliso Viejo
    Nicely done, also maybe include some links to the threads that are most commonly searched by new members. For ex: the thread that has the best debate, feedback, and opinions on suspension. or chips, etc...
    Feb 10 2006
    1999.5 A4 1.8TQM
    Twin Cities
    Quote Originally Posted by sean1.8t View Post
    haha, read the first line after the link section. ..
    and ill search and add some more links, and some of the more popular threads into it tomorrow. but this made me tired so it's bedtime.. im very interested in what the Mods will have to say about this
    smartass!. You know that I'm too much of a guru and have it all memorized so there is no need for me to read it.silly
    New Member Two Rings
    Jan 08 2007
    2000 Audi A4 1.8 Quattro
    West Allis, Wi
    Sean1.8T, that is AWESOME that you wrote that up!! I am a noob to the forum,(converted from VW) and that answered almost all of my questions as far as what to do/not to do. As I read through a lot of posts, I've seen a lot of noobs get flamed for asking what may be simple questions to them, but something you guys have heard a million times. And that somewhat made me not want to ask questions. Thanks again, and GOOD JOB!
    What the F#CK is JUICE?!
    Mar 15 2006
    Changes monthly...
    Oh!! thought of something else.... mention aftermarket stereos, dash kits for the single/double din stereos, also include speaker wiring questions, subwoofer . etc. what can and cant work with the OEM headunit and aftermarket ones. That might help too. Also, possible mention aftermarket raceseats and how they need sliders/rails and custom diode mod. etc
    EUROPROJEKTZ
    Feb 10 2004
    2009 A4 2.0T Sedan
    Good job, thanks for stepping up, Sean. I'll talk to the others about making this a Sticky.
    CURRENT: '95 Ur S6 Avant | '12 A6 3.0 TFSI sedan
    New Member Two Rings benzteck's Avatar
    Dec 15 2006
    01.5 A4 1.8TQMS
    Spokompton WA
    Damn fine job, hopefully they will sticky this, maybe you could write to change your timing belt before modding if you have 75K+ miles on your newly purchased A4(this is my weekend project)
    Jan 03 2007
    R32
    Plymouth
    Wow that is quite the explanation!! Impressive! Thanks for the time and effort this will deff help alot of people!
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    ATW KO3 B5, E36 M3, 325e
    Ashland, Oregon
    Lets just hope poeple read it.
    sticky it.
    -Nick 1986 325e
    1997 M3
    2000 A4 1.8T Quattro
    Senior Member Four Rings CSHO1.8t's Avatar
    Oct 16 2006
    Snowboards and Beer Pong
    The Upper Left
    the dumbest question is the one you dont F***ing ask. if a person is too involved in this website that my friends and i like to call "the ZINE", and can't deal with new people who want to know and learn more about B5 AUDI'S then they need to chill. if someone posts a "dumb" question, dont respond to it. let other people do that. A lot of people on this site think they are hot shit, but guess what? they really arent. everyone who owns an audi is hot shit IMO. let people ask your so-called dumb questions and answer them with respect. And please, i hope nobody thinks im disrespecting them because im not.
    0000
    New Member Four Rings a4cefed's Avatar
    Mar 15 2005
    06 GTI / 02 325ci
    chicago
    Wett (Wetterauer) also makes a k03 and k04 chip. might wanna add that to the list.
    nice job, way to step up. as time goes by and we get some good threads, maybe you can add the links in here that might help people out.
    06 Reflex Silver GTI Package 2 DSG
    [ Vogtland Race Springs/A8 wheels/Eisenmann Exhaust/Eurosprot Intake]
    For weekly Chicago meets/ GTGs check out :
    Illinoiseuro.com
    Veteran Member Three Rings Ado's Avatar
    San Jose, CA
    nice job. i bet that took a while. they dont even need to do research now. you cover alot of very important stuff. this should be sent out via email to every nooby.
    New Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Very well done and I suggest to keep information concise and organized that submissions etc... are handled in just one post or "Sticky" so comments and non relevant post are not possible. If it is worth adding we could put a poll post up and see if it gets voted in. Also I think the "Sticky" should be a little more inviting and say something more along the lines of "Please Read here before 1st post Most frequently asked questions can be answered by reading here first"
    Mar 15 2005
    06 GTI / 02 325ci
    chicago
    Re: :::::READ THIS GUIDE BEFORE 1st POST!!! THIS WILL ANSWER MOST COMMONLY ASKED Q'S:
    Illinoiseuro.com
    Veteran Member Three Rings jbrentd's Avatar
    Oct 31 2005
    '01 A4 Avant, '91 CQ, '08 FX35, '95 YJ
    Tulsa, OK
    One comment/question: Can you confirm that a chip is available for the 12v? I am unaware of one.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    there is no chip for the 12v, it uses the hitachi ecu instead of the bosch motronic and they never quite figured out how to crack it.
    2000 Audi A4 1.8TQM
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    99 A6 Avant, 01 Allroad 6mt
    NoVa
    I may have missed it, and I know there was some TIP bashing at the top, but none the less, there is a decent group of us with TIP's, and I was wondering if we can add some things about the TIP chip from GIAC, as well as the limitations on modding (most believe K04 is biggest, while others say PES 28 with no problems)... I know it is not as desireable as manual, but it has its pros and cons like any other option, and has aspects of modification that are unique to it.
    PS Thank you for doing this!!!!!
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    01.5 Pearl Stage 3 s4 AVANT
    down town long beach
    hey guys what intake will give me the most power?? will i hear the blow off valve...
    Senior Member Three Rings lovintheboost's Avatar
    Aug 22 2005
    a4, chevy silverado
    bonney lake wa
    good job man
    just a side note under "full gt28r" you have it listed as 400chp im guessing you left out the "S" may confuse some of the new guys who will, should be reading this
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    Good thread..
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    G'job Sean
    We'll all add as we go along, etc
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    Sep 17 2006
    SL,UT
    Quote Originally Posted by lovintheboost View Post
    good job man
    oops! good catch..
    so whats the consensous on this? sticky or did i waste my time?
    Veteran Member Four Rings bellofello's Avatar
    Sep 19 2006
    1992 Chev K1500 reg cab short box/with 3500 diesel drivetrain. 1992 Cadillac 60 Special "pimp juice"
    Ontario, Canada
    not only did you waste your time, you've wasted every soul on the internets time. assclown....
    but seriously good job and patience. I'f I'm not too lazy I might write a 2.8 section for you or something like that. Or just put the link for the "2.8 after market parts" 5 page thread, it has most of the stuff.
    rable rable rable....STICKY IT....rable rable rable
    -1999 A4 2.8 quattro
    neuspeed race springs/bilstein shocks
    custom exhaust/intake
    jhm shifter trio/bunch of 034 mounts
    www.gbaycars.com
    Veteran Member Four Rings audisnapr's Avatar
    Jun 06 2004
    1993 Ford E250 Sportsmobile, 1990 Corrado w/ VR6 swap track car, 2011 Mazda3 S Sport 5dr
    nicely done sean - give the the tip and 2.8 guys a break though ;-)
    also, there is no ELIM GT28rs - it's simply called the GTRS. I know the GTrs is based off the 28rs, but just so when the newbs go looking for the Elim GT28rs on ATP's website they don't end up accidentally buying the full GT28rs and expect it to bolt right up.
    so...
    ELIM GT2X
    ELIM GTRS
    and full GT28rs... among all the others of course.
    Senior Member Three Rings Mr.Black's Avatar
    Feb 14 2004
    German aluminum und schteel.
    nice. STICKY!!! that's the one AUDIA4_18T wrote for the b6's i refered to in the other post about noobs. someone should shoot him a PM thanks... oh and thank you sean!
    Was du liebst, bringt dich auch zum weinen.
    /// Ich liebe mein Audi! ///
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: B5 A4 New Member Guide/FAQ! Answers to the most commonly asked questions!
    Stuck, with some slight alterations to the title. Thanks guys, keep up the good work!
    Veteran Member Four Rings LateraLex's Avatar
    Jun 13 2005
    A4 1.8tQM 01
    the mean streets of Boston
    Nice contribution
    What's that acronym?
    1.0bar - measurement of boost, about 14.5 psi
    1.8TQMS - 1.8 turbo engine, Quattro, manual transmission, sport package
    12v - 12 valve 2.8L (1996) only sold in US market.
    710N - Popular upgrade to stock DV
    AEB - Engine in 97 - 99.5. Desirable for BT applications due to big port head and forged rods.
    AFPR - Adjustable Fuel Pressure Regulator
    APR - Tuning company which sells a popular chip.
    ATW - Engine in 2000's. Small port head and forged rods.
    AWHP - All Wheel HP- if you're Quattro
    AWM - Engine in 2001's. Small port head and cast rods.
    BOV - Blow off valve
    BT - Big turbo~ basically anything bigger than a ko4 turbo.
    BTDC - Below Top Dead Center (Typically a number of degrees below TDC. Ignition timing is read in this format.)
    CA - Control arms
    CAI - Cold air intake
    CC - Clear cornered (headlight housing)
    CF - Carbon Fiber
    CHP - Crank Horsepower. also BHP which is Brake Horsepower
    D1S - Newer ballast/ bulb system for xenon lights
    D2S - Older ballast/ bulb system for xenon lights
    DBC / NDBW - Drive by cable / Non drive by wire, in 96-99.5's.
    DBW - Drive by wire, in 00 & 2001's.
    DMFW - Dual mass flywheel.
    DP - Downpipe
    DTS - Drivetrain stabilizer
    DV - Diverter Valve
    EBC - Electronic boost controller
    Ecode - European standard headlight housing
    ECU - Electronic control unit (cars computer)
    FMIC - Front mounted intercooler
    FPR - Fuel Pressure Regulator
    GIAC - Popular chip manufacturer
    HFC - High flow cat
    HID - Xenons headlights
    inHg - Inches of Mercury (Vacuum)
    K03 - Stock turbo
    K03 Sport - Used in 2000 and 2001's. 00 had a 3mm shaft, 01 had a 4mm shaft.
    K04 - Upgraded turbo which uses the K03 housing
    Limp - Happens when overboost is detected. The car will not boost over 8psi until Limp is cleared.
    LWFW - Light weight flywheel.
    M1 - Mobil 1 oil
    MAF - Mass air flow sensor
    MAP - Manifold Absolute Pressure (sensor that reads charge air pressure on ATW and AWM motors. Located on SMIC)
    MBC - Manual boost controller
    N75 - Solenoid valve which opens and closes to allow air pressure to the wastegate
    PES - A tuner which makes a popular supercharger for the 2.8's
    PSI - Pounds per square inch (boost)
    s/w - Software
    SMIC - Side mounted intercooler
    Snub - Snub mount
    TB - Timing belt
    TBA - Throttle body alignment
    TBB - Throttle body boot
    TDC - Top Dead Center (When Pistons are at top of stroke and all valves are closed)
    TIP - Turbo inlet pipe, or Tiptronic (automatic cars)
    TP - Testpipe
    TRE - Tie rod end
    UNI - Unitronic, popular BT software
    VAG - Volkswagen Audi Group (also used to talk about computer software needed to read codes)
    WHP - Wheel HP
    WOT - Wide open throttle, when the pedal is pressed all the way in
    Sep 17 2006
    SL,UT
    sweet! i tried like 4 different titles but couldn't get the right combo i felt was appropriate. but i like yours
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Nuevo México
    sean, maybe you could add that post i had with all of the bulb numbers to the list.
    edit: found.....
    http://www.audizine.com/forum/showthread.php?t=111598
    2001 AR: Timeline
    [aka 4Ring_Jelly]
    Sep 17 2006
    SL,UT
    Quote Originally Posted by 4Ring_Jelly View Post
    edit: found.....
    done
    this thing could get pretty intense if we get a bunch of links like these in here. im thinking of adding the Suspension thread and the "post up your XXXX colored cars with wheels" threads
    Sep 19 2006
    Ontario, Canada
    Hey Sean, add this thread under the bit when you talk about the 2.8's it has most of the stuff covered that can be done to the v6'ers. If you want of course :D
    http://www.audizine.com/forum/showthread.php?t=110257
    www.gbaycars.com
    Jun 06 2004
    sean - here's the link to all the differences in the B5's: http://ctny.audiworld.com/mark/a4/diff
    Veteran Member Four Rings 1 ate T's Avatar
    VW Jetta GT, 01 Eclipse GS
    Newark,OH
    What the fack... I know mine wasn't as long, but it was never even considered for a stick.
    I'm pretty sure it's cuz Evil-Audi pretty much hates me lol.. oh well, looks good
    2000 A4 1.8TQM - Sold
    Will be back in an Audi this summer!
    Sep 17 2006
    SL,UT
    Quote Originally Posted by 1 ate T View Post
    no that's not it(i don't think). but i asked about making yours a sticky in another thread and this is what ripple had to say about it:
    Quote Originally Posted by RippleChip View Post
    Well lets just say the opinions are a little different. That thread has some very good information, lets say we start a new one and keep it away from discussion and just have it complete submission of technical information. The more that gets amassed the better it will be, and we will work to make it all nice and coherent.
    Also, the Easter Egg sticky for some reason was lost during the migration, it was not taken down for any reason. Trying to figure that out, but we may just want to start a new one.
    I'm all for this, this is my home forum. B5
    New Member Three Rings
    Oct 19 2006
    Santa Clarita, CA
    Just a heads up, I was running the GIAC X-Chip on my 2001.5 and the difference between that and the K04 + Hammer (which I am running now) is DEFINITELY more than just a hair. It is like night and day.
    Just a bit of info
    2001.5 A4 Quattro - Tiptronic
    K04
    Hammer File Software
    Injectors
    Koni Coilovers
    Forge Bypass
    Sep 17 2006
    SL,UT
    ^^umm.. read it again more closely..
    everything is already in there
